Silicone Vacuum Hoses
Old 03-09-2003, 12:36 PM
Cebby's Avatar
Do the universal kits of colored silicone vaccuum hoses fit our 3.0? How hard are they to put on?
Old 03-09-2003, 05:13 PM
1Runner's Avatar
MY GOD MAN...... YOU'RE AN ANIMAL!!!! How in the name of all thats decent am I ever supposed to catch up???
Sorry I have no expierience w/ the silicone kits. It seems to me there was a pretty broad selection of inside dia. hoses.... IF I'm thinking of the right things. Should be a do-able switch.
Old 03-09-2003, 06:09 PM
Cebby's Avatar
Just getting my ducks in a row...
Old 03-10-2003, 12:17 AM
butnut's Avatar
I ordered my hose from hose techniques. They have a sample pack you can order first to pick color and match sizes. I went that way because I customed my order with 2 colors and I wanted to do a few more hardline wraps than the kit would allow. I used Earls annodized clamp ends. They have matching zip ties you can use. Good product and service. Their site seems down tonight. Maybe try later...
hosetechniques
Old 03-10-2003, 02:20 AM
metal22lica's Avatar
that sure is purddy Brian...How much did that run ya if you dont mind me asking?
Old 03-10-2003, 09:57 PM
butnut's Avatar
A little over a hundred bucks...their stuff is high quality and an upgrade over rubber, plus it looks kool. Check out their site for more info and endorsements. Lots of imitators out there.
Old 03-11-2003, 02:29 AM
Cebby's Avatar
Brian,
Thanks for the info. That link you posted is incomplete. Could you edit it? I'm just getting "http://".
Thanks
Old 03-11-2003, 05:21 AM
mmack66's Avatar
Here is the link to Hose Techniques-
http://www.hosetechniques.com/
Old 03-11-2003, 06:35 PM
Cebby's Avatar
Thanks for the link!!
Old 03-11-2003, 06:49 PM
ATC
ATC's Avatar
I am also using the Hose Tech line of silicone hoses & they are great. I didn't order a kit however. I just used hose I had left over from when I used to build up SAABs. I can't say enough about how good these hoses are. They fit really tight & are hard to remove. When I as running 20+ psi of boost on my last SAAB I would blow off some of the factory hoses. After I switched to the silicone lines that never happened again.
Old 03-11-2003, 07:34 PM
Woodbert's Avatar
Brian,
Dats' a clean lookin engine Brah.
I'd like to get some of those blue hoses for my 3.4L. I've been meaning to buy that TRD oil cap to...
Old 03-11-2003, 10:23 PM
butnut's Avatar
Thanks guys, and thanks for fixing the link Mack.
montanatruck
02-26-2017 07:07 AM
Peevedkitten
11
08-31-2015 06:57 PM
noosh
08-21-2015 03:49 AM
AppalachianOffRoader
08-11-2015 01:15 PM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: Silicone Vacuum Hoses
