3.4 liter v6 tacoma spark plug gap sparkplug question
Old 07-26-2006, 10:48 AM
kwikrnu's Avatar
My new / used truck was missing at wot and pinging a bit. It is a stock 3.4l v-6 95.5 tacoma. I decided to check the plugs and change out the fuel filter.
A trip to Autozone and $25 later I had six cheapo bosch super plugs # 7557 and a private label filter # FF692 I was on my way.
Autozone said I should gap the plugs at 0.032. I did that with a jacobs gap pliers and double checked with a small wire gauge.
I removed the old plugs which looked well worn gap was 0.065(no wonder the truc was missing-Stock ignition system can't be good enough to bridge that gap consistantly at WOT). I guess they have been in there for at least 100k miles. One was a stock plug someone had probably forgotten to change.
Fuel filter was full of crap / rust on the tank side.
Truck runs much better at WOT and no pinging.
Maybe I should have used the ngk dual ground strap but the truck has 215k miles and those plugs cost more.
On side note it passed emmisions this morning with okay #'s with the original parts.
Old 07-26-2006, 12:50 PM
mt_goat's Avatar
I think the FSM calls for .043 gap for your truck doesn't it?
Old 07-26-2006, 01:24 PM
kwikrnu's Avatar
That is why I posted. I do not have a FSM. The guy from AutoZone said the gap was .032 and that is such a huge difference between what was on there .065. The interesting thing is the solo nkg plug dual electrode had about a .045 gap.
I wonder if a dual electrode is recommended because the heat may actually bend the ground on regular plugs over time extending the gap.
I did a search and saw most people would do the gap larger than .032...
I figured my gas mileage will go way down if the gap is too small due to the small spark not igniting the entire fuel air mix.
Old 07-26-2006, 02:08 PM
Mickdady's Avatar
The dual electrode is used because of the spark waste ignition system used on your vehicle. Basically, as I remember the spark plug fires on the power stroke as well as when the opposing cylinder fires. This way the ignition system manages 3 cycles instead of 6. Someone correct me on this if I am wrong. My memory is not so good.
anyway, the reason for the dual electrode is over the standard maintence period that plug will fire 2 times as often as if it used standard ignition timing. A standard plug will wear much quicker in this circumstance.
Old 07-26-2006, 06:33 PM
Elton's Avatar
ya factory plugs are a little pricey i paid about $20 dollars for 6 but i will not buy anything but ngk or denso
Old 08-01-2006, 04:34 PM
vudbster's Avatar
This engine requires dual electrode plugs no questions asked. The FSM says so and the picture on the engine reminds you. Why doubt it, really?
Mike.
Redeth005
06-28-2018 08:16 PM
primordialbeast117
12-19-2015 12:23 PM
hiluxinargentina
09-30-2015 05:51 PM
toyhaulert100
09-24-2015 07:55 PM
Dparr2ndgen
09-08-2015 01:06 PM
Quick Reply: 3.4 liter v6 tacoma spark plug gap sparkplug question
