small cracks on side of tire...normal?
Old 05-11-2006, 12:01 PM
FORANA's Avatar
Hey folks. I have 2 year old Duelers from firestone and lately hey have developed small cracks on the side of the tire. They are on the out rim and run all the way around the tire. From there the cracks traverse into the tread. Is this normal? They are pretty fine and small cracks. Thanks all!
Old 05-11-2006, 12:07 PM
JGM
JGM's Avatar
Doesn't sound normal to me. Where did you get them? If under warranty, bring those babies back.
Old 05-11-2006, 12:09 PM
FORANA's Avatar
From Firestone. Only 2 years old. I will take them in today.
Thanks!
Old 05-11-2006, 01:19 PM
eric-the-red's Avatar
You've had them 2 years, that doesn't mean they're 2 years old. Could have been sitting around a warehouse for a while. Check here to tell how old they really are.
http://www.tirerack.com/tires/tirete....jsp?techid=11
Old 05-11-2006, 01:52 PM
FORANA's Avatar
I see your point. However regardless of the age do you guys think I can exchange them if they have these cracks? Thanks for the link
Old 05-11-2006, 02:00 PM
fireteacher's Avatar
how many miles are on them, ever put tire protectant on them, do you live near heat? id say dryrot, mine did that in san diego
Old 05-11-2006, 02:03 PM
FORANA's Avatar
35,000 miles on them, still got plenty meat. I have put foam spray on them maybe 4 times. I do live in hawaii so it could be the heat and sun.
What I really want to know is if I have grounds to ask for new tires under the warranty.
Old 05-11-2006, 02:20 PM
firemedic's Avatar
If you bought them new from a tire dealer a couple years ago, it definitely sounds like a defective tire to me. Take a look at the warranty (should be able to find it online, if you don't have a copy), you may be elgible for a tire replacement, but it may be "prorated", not free.
Old 05-12-2006, 02:19 PM
Gerdo's Avatar
It sounds like "Dry Rot". It will happen if a vehicle is "stored" parked on concrete. The concrete will draw the moisture out of the rubber. It usually doesn't happen to a vehicle that is reguraly driven.
Old 05-12-2006, 05:08 PM
terryjmatthew's Avatar
What is the production date on the tires?
Look for a series of numbers on the sidewall starting w/ DOT and get the last four digits. That will determine the week and year the tires were built.
From your description it sounds purely cosmetic, but run it by your local Firestone and let them take a look at them.
The Bridgestone Duelers have a manufacturer's defect warranty for five years from date of purchase or six years from date of manufacture.
Hope this helps.
Old 05-13-2006, 08:29 AM
Gerdo's Avatar
If you "store" a vehicle, park it on some peices of wood. This will keep the tires from dry rotting.
Old 05-13-2006, 08:36 AM
dwh91102's Avatar
I don't know how much of this is really the cause, but I have a friend with a show car that uses the tire shine stuff (not sure what brand). The first winter it sat in the garage all the outside of the tires did this, but the inners (facing towards the axles) were just fine.
Doug4320
03-24-2018 10:11 PM
BeMiceElf
10-10-2015 09:40 PM
A2theK
07-12-2015 10:46 AM
horunner1x
07-10-2015 06:33 AM
Quick Reply: small cracks on side of tire...normal?
