Starting problems,1992 truck
Old 04-04-2006, 06:48 AM
jake the ssnake's Avatar
Lately (twice in the last month) my truck won't start.When I turn the key nothing happens even if I push the clutch bypass.It sounds like there is a humming/buzzing coming from the glovebox area.If I leave it alone for 15 mins it will start right back up and won't have any problems for a while.Is there a relay in that area that could be causing this?Thanks, Jake
Old 04-04-2006, 10:18 AM
AH64ID's Avatar
Mine was doing this also. I think the solenoid on the starter is bad. I pulled my starter and had it rebuilt, I guess I will see when I get home next month and reinstall it. The sound you hear under the dash is the relay sending power to the starter solenoid. I was going to test it and made sure the starter was the problem, but wouldnt you know the 3 days before I pulled it it worked great. I had been having the problem for about 6 weeks when I pulled it. Somtimes it would go days where every start took 5 minutes, then days where it was fine.
Old 04-04-2006, 10:26 AM
rentedmule's Avatar
When my starter went a few months ago I would only hear a faint tick when I turned the key, no noise from the glove box. I'd have to turn the key 6-10 times before it would catch and start normally. Mine definately was the solenoid on the starter, it worked perfect after a rebuild. Good luck
Old 04-04-2006, 10:39 AM
Snorkeldepth's Avatar
Seek and ye shall find . . . .
http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
(scroll to the top of the page)
Old 04-04-2006, 10:57 AM
kyle_22r's Avatar
i've had a wierd problem for a few months, occasionally my starter won't even click when i turn the key, and sometimes it gives a few halfassed cranks and cuts out, or cranks slowly and sputters to life. almost sounds like the starter motor is wearing out, but other times it works fine?
Old 04-04-2006, 11:09 AM
AH64ID's Avatar
That implies you are hearing a click. I had that about a year ago and had the motor rebuilt. Guess something else has gone out now.
Old 04-04-2006, 11:28 AM
Hmmm . . . . I bought a new starter before I read about the cheap fix. Now I have a new starter sitting in my garage for when the cheap fix doesn't work. It also might be handy to have along on an extended Baja trip. Good luck.
Old 04-07-2006, 03:36 PM
UPDATE......ordered starter contacts then decided to have my starter tested while it was out.Before pulling the starter I checked the two wires connected to the starter and got 12.5v from the battery and 0-4.8 from the ignition.I had the starter tested when I went to pick up the new wires and it was good.So I just replaced the main ground and the cable from the batt to starter and I'm good to go.
Old 04-07-2006, 04:10 PM
AH64ID's Avatar
i guess i need to check that on mine as well
Old 04-07-2006, 04:33 PM
87rustbucket's Avatar
i think i mentioned the cables earlier to you^
Old 04-07-2006, 05:33 PM
For the price (about $15) its well worth it.Mine looked like they were stock.With 14 yrs and 180000 HARD miles I guess it was well past due.
bigblue82
10
07-06-2015 08:27 AM
Alex Bessinger
06-28-2015 10:05 AM
dirtrider0129
10
06-24-2015 12:24 PM
slider417
06-22-2015 10:18 AM
88Toy
7
06-17-2015 09:40 AM
Quick Reply: Starting problems,1992 truck
