What causes the "brake" light to stay on?
I know it comes on when you pull the parking brake. And it comes on when the fluid gets low. But mine stays on and neither of those are the problem. What else makes it come on?
Originally Posted by regularguy412
Likely the fluid sensor in the reservoir is sinking cuz it's worn out. Disconnect the wires from the cap and see if it stops.
Mike in AR
I chased that one for a long time.
Mike in AR
I just brought one of those caps. They are between $90.00 and $100.00 depending on the dealer. Part number 84460-35050, Switch assy.
Might be able to find a used one, however it is an electrical part. Hope this helps.
My brake light comes on occassionally...I traced it to the switch behind the parking brake handle. If I jiggle the brake handle the light usually goes out. The switch is not being fully depressed probably due to a weakened spring on the brake cable. There is a spring on the cable near the rear axle. There may be a way to tighten up the slack in the cable which probably would help too.
Originally Posted by surf4runner
adjust the rear brakes first then adjust the slack in the cable. lubrication helps too
I changed out the park brake light switch and it didnt cure the problem, although, it could well be just that. There's no wire cutting involved with the fluid reservoir gauge. The cap that holds the donut has a plug on the end. Just a matter of unplugging it to TEST it and see if it is, in fact, the culprit. If that's the case, then one can choose to replace the cap / gauge.
I've noticed no decrease in any braking effectivness with the float (gauge) unplugged.
Mike in AR
Mike in AR
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
