***22re fuel filter location***
Old 01-14-2006, 08:22 PM
3.4v6's Avatar
i just picked up a 87 4runner for $940 2 days ago and have been working on it a bit. i cant seem to locate the fuel filter tho. i looked mid way through the cab thinking it would be like my taco but i didnt see anything.
Old 01-14-2006, 09:19 PM
InternetRoadkill's Avatar
it's hidden under the intake manifold (EFI versions) on the right side of the block.
Old 01-14-2006, 09:39 PM
superjoe83's Avatar
ya, its a pain to get to, my 2.7 in the taco is the same way, when i did my EFI swap i put it up on the upper intake for easy access
Old 01-15-2006, 06:22 AM
Full Boogie's Avatar
Yeah, Toyota kinda goofed on that one it's right above the starter mounted to the block with 17mm banjo bolts that are usually very tight and it's a hard place to get a wrench.
Full Boogie
Old 01-16-2006, 06:34 AM
4Hummer's Avatar
If you dont have a body lift they are a real PAIN to get at.
Remove passenger side tire, Remove acess panel inside the wheel wheel (10mm bolts) Now look above the starter and below the intake.
PITA
Old 01-16-2006, 07:03 AM
slacker's Avatar
heres a pic .... its right under the intake .
Old 01-16-2006, 08:52 AM
Elton's Avatar
smthwsn357
12-04-2023 02:08 AM
Eggslinger
06-08-2019 03:32 PM
pyramid
07-30-2015 10:05 AM
ddg71
07-24-2015 01:24 PM
Fundy Rider
07-16-2015 01:35 AM
Quick Reply: ***22re fuel filter location***
