94 toyo not firing,PLEASE HELP?
Old 01-14-2006, 07:36 PM
cgfireman's Avatar
I just purchased a 1994 toyota pickup with a 22re EFI. The seller said the truck was run about a month ago. After changing the battery i found the engine is not firing. Ipulled the plugs out, checked for fire at plug as well as at the wire itself. ialso remove the wire from the coil and nothing coming out of it either. the rotor and cap look ok also. i checked for voltage going into the coil and there is power on 1 wire. All fuses i have found seem to be ok. thanks for any help,suggestion,or info on diagrams i can get
Old 01-15-2006, 08:34 PM
chopps's Avatar
I would have the local parts store check the ignition mod. if it checks out ok my first guess would be coil.
ladybugRC
458
08-21-2020 10:41 AM
Alexdosdall
12-10-2017 05:48 PM
smilen724
13
11-08-2015 04:11 PM
bradahman
10-01-2015 09:24 AM
Robert-b83
09-28-2015 12:21 PM
Quick Reply: 94 toyo not firing,PLEASE HELP?
