Signal Lights not working
Old 12-27-2005, 09:10 AM
mandolaire's Avatar
My signal lights stopped working....when you click down, nothing. Interesting enough, the flashers work. I have checked all the lights and they appear to be working.
Suggestions? Thanks.
This truck is new to me...and I am bleeding; I have replaced Brakes, Timing Belt, Belts, Water Pump, all the fluids, and repaired a couple of big rust holes...and now this...
Old 12-27-2005, 10:01 AM
Nic
Nic's Avatar
May be a simple fix. Have you tried replacing the bulbs? You might want to get a new bulb (if you haven't already) and try one side at a time. I have had similar problems, only finding out later it was just a bulb.
Old 12-27-2005, 10:23 AM
dibble9012's Avatar
what truck is it/generation?
on my 3rd gen 4runner if a bulb is out, the blinkers flash rapidly, also, if the emer. flash button is not connected correctly, they will not work at all.
do the arrows light up on the dashboard?, do you hear the relay clicking?
Old 12-27-2005, 01:08 PM
Elton's Avatar
check the fuses
Old 12-27-2005, 06:38 PM
blown4runner96's Avatar
these are all possible scenerios... your hazards work off a different switch. Check your switch, after verifying your related fuses and bulbs are good
Old 12-28-2005, 04:48 AM
mandolaire's Avatar
Thanks to all for their replies....Last night I was starting to work on on all the the small things before tackling the combination switch. I started with the fuse panel...and I found a blown fuse. I replaced it with a 10 Amp fuse and the signal lights worked.
Looks like I'll be returning the flasher and 8 bulbs. Thanks again for your help.
John
RedRunner_87
84
06-01-2021 01:51 PM
Kalihi,HI
07-09-2015 04:29 PM
colinmil
07-06-2015 04:03 PM
Steezy96yota
07-06-2015 10:00 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Signal Lights not working
