ABS malfunction?
Old 12-24-2005, 07:08 PM
Aj_26's Avatar
ABS malfunction?
I've searched this forum and 4x4wire on my present ongoing problem with my truck. If you've seen my post on 4x4wire, pls bare with me for others may not have seen it. Any helpful suggestions is greatly appreciated.
All right, I got it diagnosed for the 2nd time and the tech gave me a different diagnosis from the first one (different shop). This truck is driving me crazy!!!
Let me know what you guys think.
1st Tech - diagnosed it with broken right front speed sensor and deceleration sensor ($1400 parts and labor).
2nd Tech - diagnosed it with since the ABS light is on the braking system is all jacked up that the braking proportion is not all equal-----> which ABS actuator needs to be replaced............WOW $$$$$!!!!!
How it started: did a panic stop last year and ABS light and airbag light came on; but looked into 4x4wire post and seems like having and not having an ABS is not an issue....so left it alone (probably why braking proportion is not distributed evenly, which screws up both of my front rotors).
Present day: Once in awhile the ABS light goes off; which gives me good braking. I've noticed right before the ABS light comes on upon braking, I've notice something grinding or a winding up spring on my right foot area(gas foot) when applying the brakes (Master brake cylinder??)and could not slow down and have to pump the brakes from me to stop------>thats some scary ˟˟˟˟˟!!
Conclusion: Don't have the funds to get it fixed the right way ( will cost over $2000 for repairs), thought about driving it to a telephone pole and just pay the deductable ($500)which is much cheaper to get it fixed; one thing I don't have an airbag
Any recommendations?? ........I hate to trade it in, truck is already paid for.
ALL I WANT FOR CHRISTMAS IS FOR MY TRUCK NOT TO GIVE ME ANYMORE PROBLEMS!!!
Thanks in advance for your input guys!! Have a Happy Holiday!!
Old 12-24-2005, 08:06 PM
jct61765's Avatar
https://www.yotatech.com/forums/show...hlight=AndyMod Maybe disconnecting it. This may help
Old 12-25-2005, 09:28 AM
blown4runner96's Avatar
Um, your airbag light came on also?????? Sounds like you have a faulty ABS accuator ot brake booster, although your airbag light coming on is peculiar. I seriously doubt it has anything to do with a broken wheel sensor wire. My brothers got a '99 Taco with a broken wheel sensor and his drives fine outside of the ABS light being illuminated all the time. What type of shop are you taking your veh to? I'd ask for an technical explanation from the mechanic him/herself. Seriously, ask questions when you take your veh in and I'd go to reputable shop that is Toyota specific.
Old 03-06-2006, 08:20 PM
Aj_26's Avatar
thanks for the input guys. I ordered a wheel speed sensor and will be installing it once I get it. I will post the outcome of it.
Old 03-23-2006, 03:12 PM
Aj_26's Avatar
Angry
well I got the new wheel sensor, replaced it wiyh the new one AND IT IS STILL NOT WORKING! abs light is still ON!! POS!!!!!!
Old 03-23-2006, 09:55 PM
BruceTS's Avatar
Where do you live?
Old 04-02-2006, 10:53 PM
Aj_26's Avatar
Originally Posted by BruceTS
Where do you live?
southern CA, Temecula area
Old 04-02-2006, 11:06 PM
Mr. Bob's Avatar
DO you know what ABS code is being set????
JimiJams
09-28-2015 06:14 PM
charlie_fong
09-27-2015 10:06 PM
matt1833
09-16-2015 07:11 AM
EatChipsNow
09-09-2015 01:25 AM
zz_denis
09-06-2015 03:43 PM
Quick Reply: ABS malfunction?
