Power antenna mast replacement is easy
Old 11-16-2005, 03:38 PM
paddlenbike's Avatar
I was not looking forward to replacing the power antenna mast on my 3rd gen, particularly once I looked at the hardware holding the factory oversized fender flares to the body. I realized that you only need to pop out 3 of the plastic fender liner clips and you need not mess with the flare itself. Peel the liner back and unbolt one bolt that attaches the antenna assembly to the body, unscrew the chrome nut up on the body and pull the assembly down to tire level (remove wheel/tire by the way). Remove six screws from the assembly and separate the power antenna assembly so you can pick out what's left of the plastic toothed rod that raises and lowers the antenna. Reassemble. Turn off radio and feed in new mast/rod assembly. Done.
It usually takes me 10X longer than everyone else to complete a job, but this one was done in an honest 2 hours.
Old 11-16-2005, 03:45 PM
Godzilla's Avatar
my mast was stuck 6 inches from goin all the way down. with help from a YT member I learned that all you have to do is put the radio on and when the mast goes up, give a tug (after loosening the chrome nut). the antenna mast and plastic spine looking things comes right out. after you just feed it back in when you hit cd and the motor pulls it back in. FYI if anyone has there antenna not going completely down, first check for a bend , and second check that black plastic stopper. for some reason mine seized on the mast making it unable to go down. I loosened it and all is well.
Old 11-16-2005, 03:54 PM
Unfortunately mine was broken down at the bottom--I initially tried reaching down into the antenna with one of those mechanic's "grappler fingers" to extract the broken parts, but to no avail since I discovered later when I took the unit apart that the broken part was completely inside the drum.
Old 11-16-2005, 04:07 PM
Godzilla's Avatar
did you take any pics along the way? im sure a write up that explains an easier way would be appreciated by all who suffer from antenna mastatitis..that didnt sound good..haha
Old 11-16-2005, 04:13 PM
Gangus2006's Avatar
Mine was bent a tiny bit so it stuck abotu 3-4" from all the way down, and while leanign over to change out a wiper, i broke it, so I did the Taco Whip mod.
Old 11-16-2005, 09:59 PM
mach4's Avatar
Replaced mine about a month ago and it went smooth.
The "gromments"/clips were the biggest pita.
My local stealership did hook me up...they gave me extras from mechanic stock as damaged mine getting them out.
Cleaned the motor out since it had several broken sections of the plastic teeth in it.
Put all back together.
Turned the radio ON, then OFF.
As the motor was working after turning the radio off, I fed the plastic tail of the mast and whaalaaa! It sucked it rightin. Had to turn the radio on and off again to center itself and job done.
Quick easy job thanks to yotatech!
Old 11-16-2005, 11:12 PM
BajaRunner's Avatar
hehe
Ive gotten this job down.
My attena usually falls out about once every few months... the nut gets loose over time? I donno I always forget about it and then im sitting there turning the radio on and the thing just keeps going up and falls out to the ground
Funny.
Old 11-17-2005, 07:08 AM
No pics, sorry. Skyrat posted some great pics in another thread, but unfortunately the internet links are dead. Perhaps he still has them on his harddrive.
Old 11-17-2005, 07:33 AM
4Crawler's Avatar
I have a 1st gen writeup on-line:
- http://www.4crawler.com/4x4/CheapTri...ent/index.html
Old 11-17-2005, 11:21 AM
My '88 Supra had the same cable & drum as your 1st gen 4Runner....what a PITA! The newer plastic toothed kind are more reliable and much easier to fix, IMHO.
RedRunner_87
84
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
skoti89
07-08-2015 12:05 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Power antenna mast replacement is easy
