2003 toyota seqouia cuts off in gear
I have A toyota seqouia limited 2003 that starts right up and runs fine,
but when I go to put it in drive or reverse it shuts right off,
someone told me that it may be the idle air control valve, because it runs just fine when not put in gear and also if I put the car in neutral and then put it into drive or reverse it will move and I have actually driven the car down the street when doing this, but it feels like it wants to cut off.
the fuel pump and fuel pressure is just fine, so I just cant figure out why it would cutoff when put in gear, it goes thru the gears just fine and im still trying to figure out why when I put it in neutral that it moves,
Any info would greatly be appreciated.
voiddweller
19
05-02-2016 09:10 PM
FS[SouthCent]: Toyota Trail Gear 5.29 Ring and pinion x2 NEW
YotaLogic
12
11-17-2015 06:27 AM
