Torque spec for 3rd Gen oil drain plug ?
Old 07-08-2002, 05:52 AM
nrgetic99's Avatar
Looked up and down for this and cannot find.
Found nice quotes like "Tighten firmly without stripping threads" WTF !!!
Anyway, I am thinking 60 lb INCHES tops.
Anyone ?
P.S. I have around 7500 miles on the Series 2000 0W-30 and will have it analyzed here in the next few days.
David
99 4Runner SC "Highlander" before corporate stole the name.
Old 07-08-2002, 07:22 AM
dlotoy4runner's Avatar
Re: Torque spec for 3rd Gen oil drain plug ?
Anyone ?
David
Dude are you crazy!!!! :eek: That will strip it FOR SURE!!!! 60 LBS OF TORQUE IS TOO MUCH. 20 LBS is plenty
Old 07-08-2002, 07:24 AM
HBoss's Avatar
Yeah dude, you'll kill it w/60 lbs.
20 lbs is approximately hand-tightening w/o reefing on the wrench. That is usually what the torque spec is for an oil drain plug.
Old 07-08-2002, 07:52 AM
Hbum's Avatar
The man quoted inch pounds. 60 in. lbs. is 5 ft. lb.
The correct torque is 29 ft. lbs. or 348 in. lbs.
Old 07-08-2002, 08:22 AM
HBoss's Avatar
Woops..didn't notice that part. Thx for the correction. I must have been
jalaber's Avatar
Factory spec for a 1999 v-6 is 27 Ft-Lb.
Part # for a new drain gasket is 90430-12028.
Old 07-08-2002, 09:11 AM
nrgetic99's Avatar
Thanks all,
I will re-torque it tonight...
...I did a huge out of the over torqueing comment.
I wrote the INCHES in upper case so that it would be clear I became very familiar with lbs ft and lbs in when I did my SC install.
Anyhoo, great source of info here yet again..
David
Old 07-08-2002, 11:43 AM
Hbum's Avatar
We did fall down somewhat. I notice you got the gasket part number on Outdoor Wire. It was correct, also.
The 29 ft. lbs. is from the 2000 shop manual.
Old 07-08-2002, 12:06 PM
butnut's Avatar
I'm installing the Fumoto drain valve on my next oil change. I do my own and I hate the mess. This makes life easy when I do my Amsoil analisys too.
butnut
bigjstang
08-25-2021 12:41 AM
RedRunner_87
84
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
Gamble_STi
07-07-2015 07:54 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Torque spec for 3rd Gen oil drain plug ?
