Pre 84 Trucks 1st gen pickups
82 Toyota 4x4 w/Tranny issues - what's the best solution?
Old 08-28-2005, 04:39 PM
82Yoda4x4's Avatar
Hey all, got an 82 4x4, i've had it for about 6 years, had to replace the tranny at about 99,000 miles due to wierd squeaking/grinding sounds starting in 5th gear, then 3rd, then every gear but 4th...of course I just replaced the stereo and drove it to Mexico, and only replaced the tranny when it got so bad I figured it was gonna just blow up soon....anyways finally got it replaced with a rebuilt transmission and was good to go....
so 12,000 miles later, i've got the same squeeking/grinding sounds, (guess it's a bearing issue?) and want to fix em this time for good!
My question is , what's the best solution for this issue? A transmission from a different model year? Rebuild the one i've got with different gearing? (tires are 31x10.5)
thanks in advance for any help!!!
Brian
Old 08-28-2005, 04:44 PM
89macrunner's Avatar
your better off finding a newer tranny and using an adaptor from marlin crawler...
dont rebuild your current one because it could just keep on breaking, changing your gears in the tranny isnt needed..change the ones in the rear end
Old 08-28-2005, 04:45 PM
EWAYota's Avatar
did you replace the tranny the last time or have a shop do it?
Old 08-28-2005, 04:54 PM
82Yoda4x4's Avatar
a shop did it - don't know anything about the source/quality of the rebuilt they put in.
Old 08-28-2005, 05:00 PM
kyle_22r's Avatar
the '79-83 trannies weren't known especially for their strength. '83 had the L52 which is the strongest.
marlin crawler can rebuild your tranny with bigger bearings and a gearset from a later model G54 transmission which is much stronger. you could also put in a later model transmission but they're about 4" longer and you'd have to relocate the crossmember, shifter holes, and resize the drivelines.
Old 03-21-2011, 09:08 AM
muddigger101's Avatar
i got an 82 4 wheel drive and my tranny just went out. what transmission can i put in there that will be stronger?
Old 03-21-2011, 09:11 AM
transmission
i got an82 4wheel drive and the tranny just went out. what transmission can i put in it that will be stronger
Old 03-21-2011, 10:19 AM
Nimyad's Avatar
w56 ftw
Old 03-21-2011, 12:26 PM
what year truck does that come out of?
Old 04-26-2011, 12:36 PM
keilan's Avatar
i have 1983 4x4 and it has a 4 speed but i need a 5 speed what year or years transmission will fit in the 83?
Old 04-26-2011, 02:52 PM
83's Avatar
Wow is this the thread for everyone to jump in with their own question? If you have a question start your own thread.
Old 04-26-2011, 03:20 PM
nightstalker's Avatar
lol, nothin like gettin to the point
Old 04-27-2011, 06:09 AM
83's Avatar
I get grumpy sometimes...
Old 04-28-2011, 08:58 AM
Tsquare's Avatar
I replaced the L50 in my 1981 model with the L52 from Marlin Crawler...it's worked very well for me.....got about 6,000 miles on it. Check their website, they modify the L52 to compensate for some of the tranny's issues.
Crazy_Guy97
12
06-24-2015 04:02 PM
bobbybouche
06-18-2015 10:22 AM
crash
21
05-28-2005 10:11 AM
Corey
24
07-15-2002 07:53 PM
Krash
10
07-13-2002 09:21 PM
Quick Reply: 82 Toyota 4x4 w/Tranny issues - what's the best solution?
