Old 02-10-2016, 09:06 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Fuel System Guides
Print Wikipost
How often should I change my fuel filter?
Old 08-04-2005, 01:34 PM
WraunVT's Avatar
30k, 50k, 100k?? Does using cheap gas wear out a filter faster? Do detergents clog it up?
Thanks.
Old 08-04-2005, 02:13 PM
TACOMANATOR's Avatar
I replaced mine at 50k and it was still good. So, I would not change mine more than that. Most gas is of the same stock, only additives are different. It could depend more on how much crap you have in your gas tank.
Old 08-04-2005, 02:27 PM
Beartracker's Avatar
If your running good don't worry about it. I replaced mine at 70,000 and noticed very little difference, I just figured it was time for a little preventive service. Mike
Old 08-04-2005, 02:58 PM
WraunVT's Avatar
I am getting a bit of hesitation accelerating in higher gears. I just changed the plugs, and while it is a bit quicker out of first, the higher gear hesitation is still there. I have put fuel injector cleaner in here and there, along with a bottle of Marvel's Mystery Oil. I am going to clean and check my PVC valve after I am done typing.
Old 08-04-2005, 03:10 PM
95ToyotaPU007's Avatar
I change mine every 30K miles. I just dont want too much back pressure on the fuel pump.
Old 08-04-2005, 03:27 PM
WraunVT's Avatar
Good point. Fuel filters are $35 and easy; fuel pumps are $350 and a PITA.
Old 08-04-2005, 03:31 PM
jethro's Avatar
Good one.
Old 08-05-2005, 04:54 AM
Intrepid's Avatar
So you must not have a 4 cyl then I geuss...what a pita.
Old 08-05-2005, 06:27 AM
iGGz's Avatar
No kidding... takes FOREVER! to get them in there... I think the engineers just wanted to have a little fun with that one... but yes a major PITA
Old 08-05-2005, 11:12 AM
leiniesred's Avatar
every time you change out the engine. (that is waht toyota told me) I changed mine at 240,000 and it was fine
Old 08-05-2005, 11:21 AM
rimpainter.com's Avatar
When was the last time you did the plugs and what kind did you put in?
I did my FF at 80K. Changed my fuel pump at 87K.
Old 08-05-2005, 05:50 PM
Nic
Nic's Avatar
I changed mine a few months after I bought my truck-that is when I finally got up the nerve. It had about 110,000 miles on it at that time. I cut the old one open and it was pretty dirty-all the way through. I had a post with a picture of it somewhere.
I found the picture. Apparently it had about 120K on it at the time:
Old 08-05-2005, 06:00 PM
CoedNaked's Avatar
I was told by a Toyota technician who said when in school several years back in the Toyota mechanic program or whatever it's called that toyota fuel filters with 150,000 plus miles still had good or better filtration abilities as other manufacturers fuel filters when they are near new or new.
Old 08-07-2005, 01:26 AM
Tacoma Dude's Avatar
I got my 1st gen with a little over 145K and one of the first things I did was replace the fuel filter. Looking at it I knew it'd been done before because it wasn't Toyota OEM. I put in a NAPA filter and could definitely feel the difference.
Toyota reps have repeatedly insisted that these fuel filters are lifetime. I'm more prone to replace mine at 100K. I'm coming up on that number with my Tacoma. I'll definitely post whether or not I feel much of a difference.
Old 08-07-2005, 06:46 AM
SteveS's Avatar
I wonder why Toyota made it a bolt-on item then? Oh-well I think I'll just play it safe and replace as needed or 100k. What would that cost, $0.001 per mile?
Old 08-08-2005, 04:28 PM
LSUMatt1514's Avatar
I just changed mine for the first time at 131k. I didn't really notice any difference afterwards, I just figured it was time and for $25, why not.
Matt
Old 08-08-2005, 09:07 PM
bktaco's Avatar
i have considered changing it in my 2.7L taco at 100,000 miles (very soon). but like everyone else is saying, Toyota and the dealership say that it is a lifetime filter. i am considering it now especially since i will be installing a S/C, and i think it will be a lot easier when i get the intake manifold off. i somehow doubt that it will make a difference, since my truck runs like it did 95,000 miles ago...
Old 08-10-2005, 05:55 AM
WraunVT's Avatar
I have had my ride for about a year and a half, and just hit 125k this weekend. I didn't get any service records with her. With little previous vehicle knowledge (thank god for this forum!), I have been trying to go over her with a fine tooth comb.
<96Runner>: I just did the plugs. Densos were in there and lookin rough. I put in NGKs. She seems to be running a bit better after the 17 hours of driving I jut got done doing.
Old 08-10-2005, 06:31 AM
Old 08-10-2005, 08:31 AM
Ironmike4x4's Avatar
I don't know how much of a difference it makes from a Toyota vs. GM vehicles but I would recommend replacing the fuel filter ever 30k. You'd be surprised at how often the pump will go out and it ain't cheap to replace either. Just for insurance change it.
Quick Reply: How often should I change my fuel filter?
