should there be any play in driveshaft?
Old 06-07-2005, 10:16 AM
payyourtoll's Avatar
I have horrid noises coming out from under my truck. Got under it today and there is some play in the driveshaft, at the yokes.
couple stupid questions:
Should there be 0 play, or some?
Are yokes the same as U-joints?
what is the risk in driving the car with WORN bearings/joints?
Old 06-07-2005, 10:29 AM
shiftless89's Avatar
The yokes hold the ujoint. any play there is probably from worn bearings in the ujoint caps. Mine has a little play in the slip joint and clunks every so often..
Old 06-07-2005, 10:39 AM
rimpainter.com's Avatar
If I grab the shaft and try to move it back and forth quickly, I can hear a sound in the 3rd - almost like gear teeth having a slight amount of space between them before they actually touch. I am hoping this is normal.
Old 06-07-2005, 04:12 PM
kyle_22r's Avatar
shouldn't be any play between the u-joints. most of the time the play is in the rear end and tranny/t-case(normal).
Old 06-07-2005, 06:12 PM
Adam F's Avatar
There will be just a little slack if you try and rotate the drive shaft, but it should not move around any other way. If it does, you've got problems. Fix it or it will get worse.
Old 06-09-2005, 06:15 AM
callmej75's Avatar
Put it in neutral and grab the driveshaft with one hand and grab the piece where it bolts next to the transfer case and rotate. see if there is play right at the ujoint. do the same for the ujoint next to the 3rd member.
kawazx636
10-06-2021 03:03 PM
zytra
01-24-2019 03:16 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
rmill05
09-27-2015 01:43 PM
Quick Reply: should there be any play in driveshaft?
