adjusting emergency brake/01 Tacoma
Old 05-29-2005, 03:04 PM
Beartracker's Avatar
Anyone know where I find the adjusting link for the emergency brake on my 2001 exten cab 4x4 Tacoma ? Some of the older one's were right behind the drivers door . The only thing I see that looks like it may be it is a bracket that's on the passenger side of the rear axel houseing of this 01. The cable runs through it and it has a nut on each side of the bracket.I have to go about 30 clicks and the brakes are all new on it. It only moved about 10 clicks when the brakes were replaced 2 month ago.Thank's for any info you may have. Mike
Old 05-29-2005, 03:14 PM
waskillywabbit's Avatar
How to adjust the rear drum brakes - emergency brake
https://www.yotatech.com/forums/f16/adjusting-rear-drum-brakes-easy-way-43741/
Old 05-29-2005, 04:23 PM
Thanks for the link but that is just how some are trying to adjust there brakes. Tha's not what I need . I need to adjust my stretched cable .
I found the cable adjustment and it was right where it was suaposed to be,Lol. My eyes must be bad! I've been under this truck 100 times and never seen the adjuster
Old 05-29-2005, 06:21 PM
Ironmike4x4's Avatar
https://www.yotatech.com/forums/showthread.php?t=43741
I definitely don't recommend this anymore. I wound up burning up my rear shoes by doing this. The old fashioned way and actually using the e-brake is more effective than this method.
Old 05-30-2005, 02:36 AM
Useing the E brake to adjust the brakes is fine if not over done. I'm adjusting a stretched cable.
Blamalam
03-12-2022 07:34 AM
okamikai
04-30-2018 10:19 PM
Sarcazmo
08-15-2015 08:22 PM
makemusic116
08-02-2015 05:23 PM
kirkrunner
07-27-2015 07:59 PM
Quick Reply: adjusting emergency brake/01 Tacoma
