Better throttle response
Old 05-22-2005, 04:54 PM
fo_runner's Avatar
The cable that runs from the cruise control to the throttle body seemed to have alittle slack in it, so i decided to tighten it; trying not to change the engine idle. I tightened the cable by loosening the bolt that has the cable running through it. Once the bolt was loose, i pulled the cable and re-tightened the bolt and the lock nut. Spraying on WD-40 on the bolt may help if the bolt is stuck. Now that the cable has no slack, and is tight, one little step on the pedal, and the throttle will open quicker than it was before.
Since doing this to my 3.slow, the engine feels more alive, and the throttle response is better; especially with an ISR mod.
Old 05-22-2005, 05:31 PM
L33T35T 4Runner's Avatar
that doesnt make any sense since your cruise control and throttle cable are two completely separate cables. if you think it helped you, more power to ya
Old 05-22-2005, 06:50 PM
fo_runner's Avatar
I think i got this wrong, its the cable coming off to the right of the throttle body.
The cable leads straight to something round and big, right next to the master cylinder. The bolt i adjusted is right on the throttle body
Old 05-22-2005, 07:14 PM
masterwacker's Avatar
Yeah, that sounds like your throttle cable. I looked at my engine, same as yours, and without checking the FSM I would venture to say that that is the throttle cable.
Old 05-22-2005, 07:25 PM
Joyota's Avatar
When I had my 22re apart to do the head gasket, I did the same thing, and I noticed a "big" difference. It's amazing what the little things can do
Old 05-22-2005, 08:39 PM
Tacoma Dude's Avatar
I remember reading someone had suggested picking up the slack of the throttle cable by bending the accelerator pedal so it would go lower to the ground... then someone jumped in and said, "hey wouldn't it be better to just tighten the cable?"
Old 05-22-2005, 09:39 PM
fo_runner's Avatar
This my sonund dumb; considering the people that hate the 3.slow, but the 3.slow seems to have more juice, and jumps off the line quicker after doing this little trick. Must have been the better throttle response, and "quicker opening" of the butterfly valve in the throttle body.
Old 05-22-2005, 10:08 PM
Sponsor
Tofer's Avatar
humm.. looks like i will be playing under my hood tomorrow.
Old 05-23-2005, 06:18 AM
rimpainter.com's Avatar
Another possible benefit to your adjustment is that the butterfly might be fully open at WOT when it might not have been before. Of course that is only speculation because you did not check that, but you would be surprised how many people run their vehicles around without checking the butterfly at WOT.
Simply pull the intake tube (with the engine off), have someone get in the rig and push the pedal all the way to the floor and hold. Make sure the butterfly is open all the way. If it isn't, an adjustment should be made.
On the flip side, make sure you are not over-tightening the cable or you will end up stretching it at WOT.
Old 06-19-2005, 12:05 PM
KevyWevy's Avatar
so wait, to tighten it, you're moving the nuts further to the left? cause it looks like mine is all the way over already.
Old 06-19-2005, 07:14 PM
fo_runner's Avatar
Yes, u want to make the tube with the threads, to move to the right so it can pull the throttle cable.
Old 06-19-2005, 08:56 PM
KevyWevy's Avatar
hahahaha i guess mine is tightened all the way then. that sucks.
Old 06-19-2005, 09:23 PM
Keggo's Avatar
Time for a new throttle cable then, eh?
kawazx636
10-06-2021 03:03 PM
some drunk guy
08-03-2021 06:09 PM
the_supernerd
10-01-2015 09:20 PM
shredder4286
10-01-2015 01:09 PM
Sam hain
19
09-30-2015 08:25 AM
Quick Reply: Better throttle response
