warm weather, mpg drop?
Old 05-21-2005, 10:23 PM
desert whomper's Avatar
well here in southern california its warming up fast and getting to the 90's and soon the triple digits. lately it seems like my gas mileage has dropped and im thinking maybe the warmer weather has something to do with it any ideas?
Old 05-21-2005, 10:25 PM
jimbo74's Avatar
makes sense... colder denser air produces better power results....
Old 05-21-2005, 10:28 PM
rimpainter.com's Avatar
At those temps you are probably using your AC, right? Contrary to what some people say around here, that compressor doesn't run free. The engine spins it, and you pay the price. How much really depends on how you drive and how cool you like it.
Old 05-21-2005, 10:32 PM
green91runner's Avatar
hmm, i got worse mileage in winter... 11mpg, vs the 14mpg im getting now...
Old 05-22-2005, 10:47 AM
no i dotn have ac or power steering so thats not affecting it. is there any way to counter act the warm weather?
Old 05-22-2005, 11:08 AM
Beartracker's Avatar
Never checked the milage difference from hot to cool or cold weather. I do know that my Tacoma loves the temp below 60 degrees for some reason. It runs like a scared rabbit in the cooler temps.
Maybe the hot or cold air acts different on the air sensor or the air just flows easier when it's cool.
I'm just guessing here but I'll bet the hummidity or moister in the air from one reagion to another would make a difference also.
Old 05-22-2005, 12:06 PM
Yes, there are a ton of factors that come into play here. Barometric pressure, ambient temps, humidity, oil weight, "summer" vs "winter" fuel, vehicle condition, etc...
Track your mileage and give us some figures...right now we have no idea what kind of difference you are talking about.
Old 05-22-2005, 02:08 PM
its about a 4-5 mpg a diffrence, its a pretty good amount.
Old 05-22-2005, 04:20 PM
could just be a co-incidence... had that happen numerous times with my yota, thinking the problem MUST be related to one thing or another, but just by fluke something decided to die at the same time. could be a faulty o2 sensor, or one of 100 other things.
Old 05-22-2005, 04:38 PM
Rick F.'s Avatar
I've tracked my mileage from day one for both 4Runners I've owned, even plotted the monthly average (pretty anal, huh?). 15 years of data show a significant drop in the winter, but then again, I'm in the north. The plot almost looks like a sine wave. I typically lose about 2 mpg in winter compared to summer. Also, I rarely use my A/C.
Old 05-22-2005, 05:29 PM
BT17R's Avatar
Same here. Warmer, less dense air = less power = less fuel needs = ECU and sensors doing their job.
Old 05-23-2005, 11:17 AM
roger's Avatar
I've actually been getting better fuel economy as it has gotten warmer here, and I do run my A/C pretty much all the time. It is true that the A/C uses gas, but if you drive around with your windows down the increased wind resistance will eat up all the gas you save, and probably more. As stated above, too many variables...
Anyhoo, if your mileage has dropped by 4-5mpg something is screwy. O2 sensor maybe? Clogged cat? Could be a lot of things.
Old 05-23-2005, 11:30 AM
O2 sensors are new, and vac. lines are new too. ive pretty much gone over my whole engine since i bought it back in september because i wanted to make sure it wasnt going to break down on me while i was on the trails some 50 miles away from home
Old 05-23-2005, 01:10 PM
bike4miles's Avatar
Mabe this is due to driving in 4wd? My milage seems about the same year round unless I am using 4wd in the snow. Then it drops like a rock due to the resistance and slow speeds.
Old 05-24-2005, 09:15 PM
I dont have 4wd so that isnt a factor for me
Old 05-27-2005, 03:22 PM
Ontario's Avatar
Sounds exactly like mine... and now I can have the tailgate window down!!! - Man, I've been waiting a long time to do that...
Old 05-27-2005, 03:26 PM
95ToyotaPU007's Avatar
i noticed my carbed ford 351w ran smoother and had better gas mileage in the winter. havent noticed a difference on my 95 pu.
time to get some guiness
Old 05-27-2005, 03:38 PM
im believing it might be my tps sensor. i know it is adjusted right but for some reason i get a drop in engine rpm every now and then and it is only when it is warm or hot out, something might be related. im not going to worry about it too much though, the 3.4L is going in later this summer
Old 05-27-2005, 04:50 PM
midiwall's Avatar
Does Canada suffer from the "winter gas" issues that the US does? My mileage dropped 3mpg from October to about 2 weeks ago. I'm pretty sure it's the whole winter gas thing...
Sleaker
08-26-2020 06:03 AM
bighaydn
08-04-2015 07:17 PM
JefferDean
07-31-2015 10:39 AM
coffey50
07-28-2015 10:55 AM
britishdudes2dr
07-25-2015 06:47 AM
Quick Reply: warm weather, mpg drop?
