O2 sensor Replacement
Old 05-19-2005, 03:10 PM
george16's Avatar
I"m in the process of replacing the front O2 sensor and I was surprised to see 3 rows (18 total) of holes on the original and 4 rows (24 total) for the O2 sensor I bought from URD. I chose 234-4161 from their site because I have the 49 state manual V6 4WD 1999 4runner. Can any body confirm if the extra holes would not matter at all? I haven't install until somebody can tell me if this is the right sensor. Thank you very much.
George
Old 05-19-2005, 03:32 PM
george16's Avatar
confused
Just for kicks, I decided to remove the sensor after the cat and i was surprised to see that it has the same number of holes like the sensor I received from URD. They match in size and number of holes. Now I'm confused if I got a front sensor from URD or a back one. Please help.
George
Old 05-19-2005, 05:20 PM
george16's Avatar
Update
Here's the e-mail I received from Gadget with regards to the O2 sensor I just installed.
You have the correct part. It will appear to be slightly different, but it is the correct part. Denso makes two versions, one they sell to Toyota that they can not sell to anyone else, and a slightly different one that they can sell aftermarket through us. It will work just like the Toyota one.
Gadget
For those of you who have a manual trans, you can access the connector by removing the shifter and reaching in to disconnect it. The connector is mounted above the trans and it's a pain in the a$$ to get to it from underneath the truck. My dig camera is dead so no pics.
Old 02-08-2013, 05:52 AM
jimmergb1's Avatar
I replaced the sensor on the catalyic converter but the check engine light keeps coming back on. This is on a 2005 Toyota Tundra V8. Help!!
Old 02-08-2013, 07:09 AM
aa1911's Avatar
Need some more info, what code is the CEL? That will point you in the right direction. Autozone reads the code for free if you haven't already.
Not sure if you have one or two sensors, the one that is upstream from the cat converter is the one that is important to engine input for air/fuel ratio.
Old 02-08-2013, 10:54 AM
jimmergb1's Avatar
02 sensor
I asume you mean the fault that came up on the code reader. It said "bank 1 sensor 2"
Thanks,
sandyota
02-04-2021 11:16 AM
smiley52
07-11-2015 05:16 AM
Huntingtruckcletus
07-08-2015 05:26 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: O2 sensor Replacement
