2nd gen sag
Old 05-18-2005, 10:10 AM
freshman's Avatar
2nd gen sag
Can anyone suggest what ome coil spring should i buy to level the front and rear of a 91 4runner coz it sags at the back.
Old 05-18-2005, 11:50 AM
OicnaiC's Avatar
I would suggest Downey springs, or if you want more lift Land Cruiser coils. Do a search there's TONS of info about this same question.
Old 05-18-2005, 01:18 PM
Randomness's Avatar
I would suggest OME. Get the 901's.
Old 05-18-2005, 02:00 PM
OicnaiC's Avatar
I know this is off topic but, Randomness, did you paint your stock alloys? and got any pics of em?
Old 05-18-2005, 02:15 PM
callmej75's Avatar
I got the OME 901's and they ride incredibly great and I have heard no complaints of future sagging issues. They do sit you up a little higher in the rear than the front but you can resolve that with going higher with 1.5" bj spacers or just cranking your torsion bars. I got my bars cranked at 14.5" on both sides and I still sit higher in the rear. If you are thinking of the OME's then message Strap22 and he will take care of ANY questions you may have. The guy works wonders with customer satisfaction!
Old 05-18-2005, 04:47 PM
Eric's Avatar
I recently removed a set of eibach springs while replacing it with a pro-comp lift kit. they had 0 sag, and I would seriously load the truck up. even with over 1,000 lbs of weight the truck was still level.
One time I put 2,200lbs of glass bead in the back (22 100lb bags) and the truck still had some suspension movement
Old 05-18-2005, 05:01 PM
bike4miles's Avatar
Spring Thread
Old 05-18-2005, 05:09 PM
callmej75's Avatar
bike....there was no way i was getting my ome's in with a prybar like you did! i used spring compressors, bottle jack and stood on the drum to get those things in!
Old 05-18-2005, 05:21 PM
Sponsor
Tofer's Avatar
i put in Downey HDs, they look and ride great.
Old 05-18-2005, 06:40 PM
Sponsoring Vendor
Strap22's Avatar
Here is a great setup at a great price. ONLY $216.64 plus shipping*
4Runner 90-95 OME & SDORI COMBO SUSPENSION KIT CONTAINS:
2- OME 901 Coil Springs
2- SDORI Ball Joint spacers
Old Man Emu from Australia makes the OME items
SDORI of San Diego makes the spacers.
* e-mail:www.info@trdparts4u.com w/zip code for freight quote
We also have more kits in the vendor section under 2nd Generation lift options.
Hope this helps......................
Old 05-18-2005, 07:21 PM
callmej75's Avatar
Dang Phil! Wish I would have knew about this special before i ordered just the coils or I would have gotten both. The bj spacers will be mine..oh yeh...
Old 05-18-2005, 09:04 PM
Randomness's Avatar
Yup! Painted them...sand, clean, primer, rattlecan black. They look great, the only thing I'd change is maybe do two coats of paint, and I think I'd use semi-flat black if I was to do it again, but that's totally personal preference...
BTW, that's with the 32's and OME springs/shocks
Old 05-18-2005, 09:07 PM
ROMAD's Avatar
strap22 - NOW thats a hell of a deal and one I wish I could have gotten. I am pretty sure I have $140 alone into my Downey 1.5 HD's.
Old 05-19-2005, 09:03 AM
Sponsoring Vendor
Strap22's Avatar
It's a great deal and anyone looking for quality lift options should check this out and our other options in the Vendor section. If you don't see what you need you can always e-mail:www.info@trdparts4u.com. We will do our best to get you what you need. I am sure everyone knows we carry a complete line of Genuine Toyota parts and accessories as well as ARB/OME offroad products. We appreciate all the support we get from Yota Tech members.
Thanks for the bump Romad
some drunk guy
08-03-2021 06:09 PM
suppra87
07-15-2021 05:15 PM
MichaelKLerner
10-27-2015 07:18 PM
runnermedic
13
09-21-2015 05:20 PM
reallynotamechanic
09-11-2015 11:52 AM
Quick Reply: 2nd gen sag
