Loud roar from rear-end when over 30-40 MPH and on the throttle.
Old 05-01-2005, 09:48 PM
yotaman's Avatar
Talking Loud roar from rear-end when over 30-40 MPH and on the throttle.
My 4Runner has a loud roar from the rear-end when I’m on the throttle and over 30-40 MPH. I’ve drained the oil in the rear-end and didn’t find anything out of the ordinary in the drained oil. I’ve replaced the axle bearings with no luck.
I’ve put 3000+ miles on the rig sense I’ve owned it and the noise doesn’t get any louder or quieter.
What do you guys think it could be?
yotaman is offline
Old 05-01-2005, 11:08 PM
kevin444's Avatar
You checked the drums?
kevin444 is offline
Old 05-02-2005, 07:44 AM
yotaman's Avatar
I replaced them when I did the axle bearings.
yotaman is offline
Old 05-03-2005, 07:59 AM
Doc279's Avatar
I'd be willing to bet that it is the pinion bearing - they make an awful noise.
That is the bearing closest to the driveshaft in the third member.
PM - ZUK he may be able to help.
Doc279 is offline
Davebarbier
11-03-2015 03:28 PM
Flightguy
10-02-2015 05:34 PM
kbpickens
10-02-2015 03:37 PM
the_supernerd
10-01-2015 09:20 PM
JPV
09-28-2015 03:15 PM
Quick Reply: Loud roar from rear-end when over 30-40 MPH and on the throttle.
