How do I know if cv axle is good/bad?
Old 04-22-2005, 06:38 PM
Dekri's Avatar
Im gonna be going out to the junkyard tomorrow to look for a cv axle and I was wondering how to tell if it's a good or bad cv axle. Like how to I check to see if the boot and joint are in good condition?
Pictures would help me out if you have any.
Dekri is offline
Old 04-22-2005, 06:40 PM
green91runner's Avatar
well, if the boot is torn then, steer away from it.. if the boots are in good shape, grab the axle and try to move it back and forth, the less play in it the better, easier to tell when you get the axle out, then you can try 'compressing it', a good axle will compress less then a worn out one. thats the only things i can think of. as for pictures, unless the boots are off, you wont be able to see any of the worn out parts.
good luck
green91runner is offline
Old 04-22-2005, 08:03 PM
Dekri's Avatar
thanks, I doubt I will find anything good there. Past two times I went there, there weren't any 4runners or tacomas, even if there are any, they're way to smashed up to pull anything off of em. People need to stop fixing up their wrecked runners so I can get the parts I want, lol.
Dekri is offline
Old 04-22-2005, 08:08 PM
lol, i say the same thing.. theres maybe 4 2nd-gen runners that see the scrapyards here a year, and they're pretty totalled... and by the time i get to them usually half of the vehicle is scavanged.
TheBFA
02-15-2020 06:55 AM
live4soccer7
05-11-2016 06:52 PM
JookUpVandetti
09-30-2015 08:58 AM
Cycles
09-29-2015 06:37 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: How do I know if cv axle is good/bad?
