85 22re fuel filter
85 22re fuel filter
hey
i was refered to this site to find info on how to remove wheel well or something around there to get at it a little easier....any ideas on what that thread is or a link to it????Thanks
Most people take the passanger wheel off. On my 91' there is a little half cover that comes out of the wheel well and I got by with just taking that off and using a 6" 1/4" drive extension and 12mm wobbly sockett whiles snaking my upper body between the tire and wheel well (wouldn't recomend it unless you are less that 150 lbs like me ).
Originally Posted by ktmrider37
Thanks, were you able to remove the filter easily after you took off the wheel and wheel well???
The fuel filter on a 22re is a pain, but it can be lessened:
1. take off the gas cap
2. jack up the truck high on the passenger front and put it on a jackstand,
3. remove the passenger side tire
4. remove the access plate on the inner fender
5. locate the fuel filter. It is mounted on the block below the intake and above the starter. Remove the front fuel line. I think it takes a 17mm socket DO NOT REMOVE REAR LINE
6. remove the mounting bolts, upper and lower (10mm I think, maybe 12mm). Swivel joints incorporated into either your socket extension or you personal anatomy help significantly.
7. pull the fuel filter out between the fender and frame and remove the rear fuel line. Trust me, this saves a ton of grief of trying to reach in and remove the rear fuel line.
8. remove the filter while trying to hold it somewhat level. It will have gas in it and will spill all over
9. remove plug(s) from new filter
10. install rear fuel line on the filter making sure to use the new copper gaskets at the banjo fitting
11. mount fuel filter on block
12. install front fuel line on the filter making sure to use the new copper gaskets. When installing the fuel lines make sure in both instances to ensure the gaskets are still in place when you put the banjo fitting on the filter.
13. make sure fuel line bolts are snug. Use an opened end wrench to hold the filter ends when tightening so as not to rip the filter
14. fire up the truck and check for leaks. It will take a bit of extra cranking to get it started since the fuel system has a pocket of air in it.
15. button everything back up, put on the tire, drop it on the ground and pat yourself on the back. You just beat the crap out of your knuckles, upset the neighbors, emabarrassed your wife, taught your kids and all the kids in the neighborhood all sorts of new vocabulary words to use on the playground and you saved yourself a trip to the mechanic and $35-40
Sorry for "reviving" this thread again..
But do the directions above also apply to 88 pickups (22re engine)?
Also...http://www.partsamerica.com/ProductD...Type=4&PTSet=A
will that filter be okay with my type of engine? I dont need nothing special.
Do the filters, already come with new copper fittings?
And, one last question, what is the "banjo fitting" you keep talking about? Are those the ends of the filter itself?
Also when you put a jackstand, under the truck, do you mean only supporting the passenger side, or the whole front of the truck?
...haha sry for all the questions, i like to be..."thorough"
oh yeah btw, im new to the forums. 22RE FTW.
Thanks.
-JeFF
Thanks.
-JeFF
pyramid
07-30-2015 10:05 AM
