integration relay
Old 01-23-2005, 08:33 AM
northern toyota's Avatar
Question integration relay
What does this exactly do, can I bypass it , how much for a new one, and do they make aftermarket one. The problem is that I don't have running lights, dash, speedo, fuel gauge, temperature, interior lights, I keep blowing the gauge fuse. I have this plugged in it blows the fuse, have it unplugged and it does not blow fuse, also where can I get schematics online for my truck, it is a 98 tacoma.
Old 01-23-2005, 08:51 AM
Ironmike4x4's Avatar
Well check the wires, you know you have a short to ground if the fuses are blowing, try to check and see if they are getting to the load before it grounds. Also check for loose or frayed wirings. It costs money but if you join alldatapro.com it gives you very helpful stuff for vehicle repairs.
Old 01-23-2005, 08:54 AM
Thanks I checked all the wiring and repaired all the nessasary wiring and the fuse still blows, is it possible that this unit is blown up itself. It is my last option.
Old 01-23-2005, 08:57 AM
Check the unit itself.... I know it may sound odd, but once at my dealership we had a truck come in and a nail was in the dash panel. Everytime the Speedometer read anywhere above 20mph it went dead to zero. Come to find out, the poteniometer was shorting itself out once it read the 20 mark. If not then get some type of manual to test the unit itself.
I8URSVT
01-15-2016 07:25 PM
bradahman
10-01-2015 09:24 AM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Rcbc92
09-26-2015 03:00 PM
Quick Reply: integration relay
