reverse light problem(s)?
ok my reverse circuit doesnt work..... that said, there is a wire harness that has 2 wires and exits the left side of my 5 speed tranny on my 85 truck... well this wire bundle has about a 6 foot lead and terminates with a white toyota plug... is this my reverse switch? and also... where does it hook up to? the fuses are fine.... is this harness for the clutch bypass? i am not sure if it was ever connected or not.... but would like to find out what this is, and also track down the no reverse light situation
if its a 5 speed like mine, its on the left side, i just recently had mine go out so i looked at it, i took it out and it is a ball that when pushed in sends the signal to the reverse lights, all i had to do was clean it with some alcohol and it works now.
the harness that comes out of the left side of my 5 speed tranny doesnt even connect to anything... it seems to be routed up into the engine compartment and terminates with a white 2 conductor toyota plug and just sits near my wiper motor...... doubt it being a loose ground.... maybe loose ground and loose power as its not connected... not sure if it is why me truck has no reverse lights... but would like to at least find out where its supposed to go.....
See my earlier reply, that wire usually runs over the top of the tranny to the passenger side where it connects to the rest of the wiring harness. Look over there for a dangling white Toyota plug to shove it into.
ok, where does it hook up to so i know where to look? and am i looking for the mating plug like on hte right framerail or whereabouts would it be? so it is definately not supposed to be routed up near my wiper motor on the pass. side firewall correct?
Like I wrote earlier, it runs up and over the transmission and connects with a mating connector that comes down along the firewall on the passenger side. Sort of close to where the 4WD switch from the t-case hooks up. I've never traced the wiring to see exactly where it comes from, but the main wiring all goes through the firewall on the pass. side behind the engine for the most part.
ok found it.. i dont have a harness that goes into the firewall... however, i did have the main harness that spiders out everywhere... and there was a white plug... well i plugged it in and now i have reverse lights! the clips broken so i will need to ziptie it..... but im happy.... the lights suck... going to do the 4crawler paint mod..... instead of using silver paint, can i use chrome paint?
ah, i guess that is the same paint that i got... just didnt realize it until i went home to do the mod... well im all done with it.... light output is a little better but not much... the housing for it just sucks...... its rustoleum specialty chrome paint
rushw
07-18-2015 01:46 PM
mengquis
07-13-2015 10:39 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Jnkml
07-06-2015 01:20 PM
