Which spark plugs for 3.4 Tacoma?
Old 11-11-2004, 08:15 PM
Fenderrookie's Avatar
I am due to chang my plugs. 3.4 in an '03 Prerunner. Mostly stock...... Amsoil filter and deck plate.
Any reccomendations?
Fenderrookie is offline
Old 11-11-2004, 08:22 PM
kevin444's Avatar
Denso Iridium IK 16's
kevin444 is offline
Old 11-11-2004, 10:10 PM
VolcomTacoma's Avatar
The 3.4 uses two different types of spark plugs for the driver and passenger side which are Denso and NGK. I'm sure you can pick them up at the dealer. Look here: http://www.4x4wire.com/toyota/mainte...ep3.html#plugs
VolcomTacoma is offline
Old 11-21-2004, 10:33 AM
quik05's Avatar
In regards to the two brands of plugs, I think toyota simply puts the spark plugs into the heads before final engine assembly. And the two heads that the guy/robot grabbed off of the rack while putting the engine together came from two different lots and therefor two different brands of plug.
quik05 is offline
Old 11-21-2004, 11:36 AM
roger's Avatar
Yeah, you don't have to buy three of each kind. Just get a full set of either the NGKs or Nippon Densos and you'll be fine.
roger is offline
Old 11-21-2004, 07:43 PM
I even have a sticker under my hood specifically stating to use dual electrode plugs(NGK's). They are supposively the plugs used on the passenger side under the coil packs. I'm going to change mine soon and will see what plugs the dealer has for the 3.4.
Old 11-22-2004, 11:51 AM
boogyman's Avatar
Talking
i just got the ngks from the dealer. couple bucks each, not too bad.
boogyman is offline
Old 11-22-2004, 12:01 PM
rimpainter.com's Avatar
Dual electrode or two different types of plugs for each side, or both?
Clearly the 5VZ requires dual electrode, however, the two different types of plugs thing is completely foreign to Phoenix area dealers...sounds like an unnecessary complication to me.
rimpainter.com is offline
Old 11-22-2004, 02:29 PM
Just picked some plugs up from the dealer and there was only one plug listed for the 3.4. They are dual electrode Densos. I will have to see what plugs come out of mine. Anyone try using 1/4" fuel line to thread in the new spark plugs like it shows on the 4x4wire writeup or Haynes manual? It's supposed to help not strip the threads in the head.
Old 12-01-2004, 11:25 AM
kevin444's Avatar
Originally Posted by Bud
just picked up a set of spark plugs for the taco. Dude gave me 6 densos and i asked him if it came with 2 sets of plugs. He just gave me the look and handed me six; which turned out to be iridiums for $1.50 each.
where do i go to find this crackhead? I want some iridiums for $1.50
kevin444 is offline
Old 12-01-2004, 02:03 PM
Bud
Bud's Avatar
the dude at the counter didnt read the dealers coupon carefully when i purchased the plugs. In the $1.50 coupon in small print, iridiums not included but when i printed it out on my el cheapo printer, you could hardly read the print. I didnt realize i had iridiums when i got home.
Bud is offline
Old 12-01-2004, 08:25 PM
kevin444's Avatar
print and or scan it for yt buddies
kevin444 is offline
Eggslinger
06-08-2019 03:32 PM
Alex Bessinger
08-31-2015 09:17 AM
cars-guy
07-11-2015 07:51 PM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: Which spark plugs for 3.4 Tacoma?
