Disabling day time running lights on 2003 4runner
Old 10-12-2004, 06:15 PM
sam2day's Avatar
Need the straight truth about disabling the day time running lights on a 2003 SR5 V8 4runner. The local dealer said it could not be done, but I know somebody out there has done it or know where I can get a detailed set of instructions to do it myself. Thanks for all the help.
Old 10-13-2004, 12:06 AM
Guest
fourunnabilly's Avatar
gimme a week and i will have an answer for you.
Billy
Old 10-13-2004, 08:41 AM
Good Times's Avatar
Easily do a search and you'll find your answer as topics like this has been covered alot on several boards:
Originally Posted by yosmany
A few things.
Your DRL's can be disabled. Actually you could've done it yourself. On the back of the junction fuse box (bottom left of the steering wheel) the is a fuse flash relay for your turn signals.
There are two relays one for daytime running lights and turn signals, and another for only turn signals. All you have to do is get the other relay (with only turn signals, w/o DRL) and replace it. Very easy, just a couple of screws.
Actually there are a few people on here that wanted DRL's and you probably (logically speaking) could just trade flash relays.
As a matter of fact, I was just on the dealership's computer, did a search for our trucks and saw that there is a new TSB for disabling the DRL's. But changing the relay is much easier.
Why did you want to disable the DRL's anyway? Just wondering. The TSB said that some people work on military bases that have light sensitive security monitors.
Hope this helps.
btw, if you have the dealer do it, it'll be $30!
And just incase you wanted to know where I found this information:
https://www.yotatech.com/forums/show...=disabling+drl
Good luck!
Old 10-21-2007, 11:53 AM
02Surf SSR-X 4xSport's Avatar
2003-2004 4Runners:
https://www.yotatech.com/forums/f127...ability-92211/
gillesdetrail
11-19-2019 12:56 PM
Jdgarrison
10-01-2015 05:22 PM
shredder4286
06-27-2015 09:42 AM
Mutinebullfrog
06-18-2015 01:36 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Disabling day time running lights on 2003 4runner
