Stock 22RE Specs?
Old 08-18-2004, 08:22 AM
YotaTruck1986's Avatar
Question Stock 22RE Specs?
Does anyone know what the stock 22RE specifications are? I don't have a manual for my truck. Thanks for any help.
Old 08-18-2004, 08:35 AM
AzStorm's Avatar
Which specs do you need?
Shoot me an e mail and I can give you the info.
Old 08-18-2004, 08:44 AM
Just need max HP @ what RPMS, max torque, compression, bore, stroke, or anything else you can think of. Thanks for the help.
Old 08-18-2004, 09:07 AM
kyle_22r's Avatar
22RE('85-95):
bore - 92mm
stroke - 89mm
compression ratio - 9.4:1
116hp @ 4800rpm
140tq @ 2800rpm
Old 08-18-2004, 09:11 AM
Originally Posted by kyle_22r
22RE('85-95):
bore - 92mm
stroke - 89mm
116hp @ 4800rpm
140tq @ 2800rpm
Thanks, I used to think the 22RE only had 105 hp, so you've lifted my spirits some.
If anyone has any more 22RE info, please post. Thanks again.
Old 08-18-2004, 11:00 AM
AKennedy87's Avatar
I think the 2G 4Runners and 3G Pickup 22RE's have 105 hp due to emissions crap, but fortunately for you yours has the 116hp.
Old 08-18-2004, 11:26 AM
kyle_22r's Avatar
actually i think they all had 105 or so from '83-84, 116 from '85-89, and that there was a slight increase in '89 or so due to the better plenum that was introduced. but i could be wrong
Old 08-18-2004, 12:34 PM
AzStorm's Avatar
HP and Torque Ratings
Toyota Stock Motors 1985 - 1986 - 1987 - 1988
22R 99 HP @ 4800 RPM TORQUE 129 @ 2900 RPM
22R CALIF. 95 HP @ 4800 RPM TORQUE 129 @ 2900 RPM
22RE 116 HP @ 4800 RPM TORQUE 140 @ 2900 RPM
22RET 135 HP @ 4800 RPM TORQUE 173 @ 2900 RPM
Toyota Stock Motors 1989 - 1990
22R & 22RE 103 HP @ 4800 RPM TORQUE 133 @ 2900 RPM
Toyota Stock Motors 1991 thru 1995
Same as 1989 - 1990
No 22R After 1990
Let me know what else you need.
Old 08-18-2004, 12:54 PM
AKennedy87's Avatar
Not that I need it but is there any way to get rid of the things on the 89-95 that restricts it to only 103 hp?
Old 08-18-2004, 05:03 PM
evilcow's Avatar
lots of 22re/te info here
http://www.well.com/user/mosk/
Old 08-18-2004, 07:39 PM
Thanks again for the replies.
Old 08-18-2004, 07:54 PM
jimbo74's Avatar
yeah 95 HP!!!!!
Old 08-18-2004, 10:38 PM
kyle_22r's Avatar
i'd assume it's mostly vacuum line spaghetti. i don't have any idea why the 22R would have the same rating as a 22RE in a million years though especially when the upper plenum/throttle body from an '89-up truck is a desirable performance upgrade
Old 01-29-2014, 04:45 PM
Nashman00's Avatar
A stock 22re California truck only makes CALIF. 95 HP @ 4800 RPM TORQUE 129 @ 2900 RPM "My truck currently push's 130 rwhp and 180 rwt"
I am still doing this with a stock computer and stock block wow
I did some thing good lol
RatOmeter
10-22-2015 03:17 PM
coffey50
07-28-2015 10:55 AM
1994toyota
07-17-2015 03:03 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: Stock 22RE Specs?
