Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
Landcruiser FJ60 lift?
Old 08-14-2004, 07:02 AM
JackMhigh's Avatar
Yea hi, I use to be a member on this but something got screwed up so i had to re-register, anyway i totaled my 89' and now im looking to buy this 82' FJ60 Landcruiser and i havent been able to find any kind of lift for it? Im wondering if any of you guys could help me on this.
Old 08-14-2004, 07:53 AM
joez's Avatar
Best option is just going to a SOA setup. It will net you arround 5" of lift, and even with stock springs will flex excellent. I know OME makes a lift for them, but i think its only arround 2".
I know there are a few others out there, but i will have to dig them up.
Old 08-14-2004, 10:11 AM
Yoda's Avatar
http://store.yahoo.com/coolfj40/leafsprinoem.html
There are several lifts avail. Check the above link, and check the vendors listed in the Landcruiser section.
Also, check out Steve's FJ62:
http://fastq.com/~sschaefer/cruiser.html
Old 08-17-2004, 01:39 PM
blupaddler's Avatar
SOA can be costly, but worth it from what I have heard. However, check out...
http://realcruiser.com/index2.html
he has a real nice 60 with a SOA
www.fj60.com
www.man-a-fre.com
www.ih8mud.com
forum focused mainly on Landcruisers
Old 05-31-2009, 05:15 PM
hught's Avatar
Depending on your expertise, SOA is the way to go.
SOA will get you around 6" and allow you to fit bigger tyres (37's easily) which helps with your under-diff clearance as well as other things.
If your truck is straight, it will look awesome too!
Have a look at mine
Old 07-08-2009, 11:55 AM
Trail_Banger's Avatar
Hey guys,
This is a little off topic so sorry to hijack the thread. Where can I find differential ID info for the FJ60? I am probably going ot buy one soon and would like to know what kind of axles I have. I know of the sites for trucks, tacomas and 4Runners but don't know where I can get info on land cruisers.
Thanks in advance!
Old 07-08-2009, 12:35 PM
Yoda's Avatar
IH8MUD.com
They have a separate section for each type cruiser
FJ60 uses the same diff size as FJ40, but are 3.73 gears. FJ62 went back to 4.11 gears
Old 07-09-2009, 09:28 AM
Sweet. Thanks for the info. BTW, I found this website after posting yesterday....http://www.cruiserfaq.com/00-00.php
Good stuff there.
Old 07-09-2009, 09:49 AM
scuba's Avatar
ZOMBIE THREAD ?!?!?! RUN FOR YOUR LIVES !!!
Old 10-14-2014, 03:15 PM
marshcruiser82's Avatar
Do yall know if the shackle reversel kit works from 4wheelparts will work on a 82 fj60?
http://www.4wheelparts.com/4wheelpar...=101&t_pt=3647
Old 10-14-2014, 03:29 PM
So i just checked it out and those are just shackles. Is there a way to put the axle on the bottom of the leaf springs? What would be a cheaper simple lift? I looked at the hell for stout website and it really didnt have what i,was looking for.
suppra87
07-15-2021 05:15 PM
1uzRunner
63
11-10-2018 03:58 PM
AkitaDog
09-03-2015 09:01 PM
matthew138
09-03-2015 08:21 AM
Ryall
09-02-2015 06:48 AM
Quick Reply: Landcruiser FJ60 lift?
