Nissan wheels fit Toyota?
Old 04-23-2004, 05:16 PM
MNBOY's Avatar
Local guy here has a nice set of wheels with new tires for sale dirt cheap. Will the 6 bolt wheels off a Nissan truck fit a Toy?
Old 04-23-2004, 05:24 PM
WATRD's Avatar
If they are six lug on 5.5" spacing, they should.
Old 04-23-2004, 05:31 PM
Guest
Yoter's Avatar
Ive heard Nissan has a larger six bolt pattern.
I know for a fact Chevy & Toy have the same 6 bolt
I think Ford & Nissan have the same 6 bolt
Old 04-23-2004, 05:42 PM
shazaam's Avatar
I'm pretty sure nissan wheels fit a yota
Old 04-23-2004, 06:20 PM
MNBOY's Avatar
So that's a "measure them first", "probably not" and a "probably". Anybody know for sure?
Old 04-23-2004, 06:34 PM
dbikeman's Avatar
I do know for sure. My previous truck was a Nissan D21 Hardboy 4x4 and yes they will fit.
Old 04-23-2004, 06:36 PM
MNBOY's Avatar
Thanks.
Old 04-23-2004, 07:01 PM
Guest
Yoter's Avatar
Interesting. That would be so funny if he bought $400 worth of wheels and them not fit. But it would suck if the seller would not take them back. Glad that Dbikeman is 100% positive they will fit.
Old 04-23-2004, 07:03 PM
Scofco's Avatar
I suggest doing a test fit before you buy them.
Old 04-23-2004, 07:09 PM
Supercharged's Avatar
Nissan wheels will fit Toyota as long as they are six lugs, but Toyota wheels may not fit all Nissans due to the fact that Nissan have much bigger hubs.
Ford does not have a six lug pattern, they are all either 5x5.5 or 5X135mm.
Old 04-23-2004, 07:13 PM
Guest
Yoter's Avatar
Isnt a Ford F250 a half ton 6 lug pattern?
Old 04-23-2004, 07:19 PM
No, they do not. They have either 8X6.5, 7X150mm or 8X170mm
Old 04-23-2004, 07:42 PM
Guest
Yoter's Avatar
I was asking about Ford lug patterns. Were you backing me up that Nissan 6 lugs are not the same as Toyota?
Old 04-23-2004, 07:47 PM
dbikeman's Avatar
The Nissan wheel should fit fine. The factory XE wheel is a 15x6 with about 4" or so of bs. The SE wheel is a 15x7 with about the same bs. Most se's came with 31s. Also when I bought my Mickey thompson classic IIs the tire guy said that toyota and nissan 4x4's use the same wheel.
Old 04-23-2004, 08:42 PM
95red4runner's Avatar
Ford has a 5 lug, 7 lug, 8 lug, and yes a 6 lug. It's on the 2004 f-150.
Old 04-23-2004, 09:58 PM
Yeah, I forgot about the new F-I50, but they are 6X135mm- not 6X5.5 like the Toyotas and Nissans. The only six luggers that I am aware of are:
6X5.5- Nissan, Toyota, GM, AMC, Mazda, and Mitsubishi
6X135mm- Ford (2004)
6X4.5- Dodge
Old 04-24-2004, 09:50 AM
MNBOY's Avatar
It really wouldn't be that funny, but I also wouldn't be dumb enough to buy them without checking, if I couldn't return them.
Thanks again guys for the info.
Old 04-25-2004, 07:21 AM
934rnr's Avatar
The 6 lug 5.5 pattern is the same on 4wd toyota, chevy, izusu and older jeep waggy's and some mitsubishi montero's.
The only thing you have to worry about is the center hole clearence I bought a cheapo alloy isuzu wheel as a spare and tryed to fit it on the center hole was too small and wouldn't fit my 4 runner so I gave it top my buddy who has a nissan I think it fits on but it's really tight. You can fit toyota wheels on nissans as well.
Chevy wheels I know for a fact won't fit nissan or toyota because the center hole is way too small.
Mitsubishi montero wheels will fit a nissan I do know that.
I had used the older toyota alloys on my 95 pathfinder the only thing that didn't work because it requires a recessed collar lug nut for the toyota alloys and the thread pitch is different on a toyota's lug nuts 1.5 thread pitch vs the nissans 1.25 pitch.
I have seen a 4 runner running around with 15x6 chrome stock steel wheels from a nissan as well though. I don't know about the alloy center hole clearence though I think the center hole on the nissan wheel is a little smaller than toyotas not by much though but it would be enough so it wouldn't work though.
Anyways good luck I would just get aftermarket wheels they tend to be alot less expensive.
Old 04-25-2004, 05:14 PM
Guest
Yoter's Avatar
[QUOTE=934rnr]
But wheels purchased for Toyota that are after market rims will fit Chevrolet.
So everyone knows for a fact that the 1990 through 1995 Ford F250's did not have a six lug pattern? I swore there was. But maybe I am wrong.
Old 04-25-2004, 07:33 PM
934rnr's Avatar
[QUOTE=BigBadBlue]
I thought some old bronco II's had the 6 lug pattern not sure though.
I might be wrong but most of the newer F-150's and F-250's had the 8 lug pattern and the older ones were a 5 lug.
Here's some info I did find though from a ford forum:
1989 – 2001 - Ford Explorer – 59 Ό - ½” flange to flange.
- All explorer rear ends are the same 5 on 4 ½” bolt pattern.
- 8.8” rear end - come with 3.25, 3.55, 3.73 and 4.11 gears.
- 89-94 drum brakes only.
- 94-97 drum or disc. brakes
- 97-01 disc. Brakes only
- Can use an 8” rim with 3 ½” backspacing and P235/75R-15 tires
- Number 3 choice for ease of installation and price.
1957 –1972 F100 9” heavy duty - 5 on 5 ½” bolt pattern
- Is supposed to bolt right in without moving spring pads.
- Measures 61 Ό” flange to flange
- To switch to the 5 on 4 ½” car bolt pattern - Use two driver’s side axles, both side backing plates and drums from 72-79 Torino, Ranchero, LTD II or 77-79 T-bird or Cougar o
Quick Reply: Nissan wheels fit Toyota?
