knocking noise coming from front left tire
after i switched to my new tires about a week later i started hearing a knocking noise that is coming from the front left tire. there is nothing for the tire to rub on, ive already checked the bearings and they are fine. i just recently shot grease into the ball joints and i can still hear the noise. it happens at all speads while in 2wd. i havent checked to see if its there with the hubs locked. any ideas or opinions would be greatly appreciative
thanks
jayson
thanks
jayson
Originally Posted by 86toyota
Your lugnuts are loose
Did you get the right lug nuts for the steel wheels? Do the wheels fit onto the front hub correctly? (backspace OK, center hole OK?)
Have the wider wheels made a worn front bearing more noticable?
My '98 does this too but I'm all stock in the front end. Mostly noticeable at slow speeds over moderately rough road and tight turns. The CV joints and wheel bearings feel tight, I don't think that's it. If I crawl forward slowly a bit and brake...klunk! Then back up slowly and brake...klunk! It makes me think it's something in the suspension linkages or ball joints. Been doing this for about 2 years now and seems to be more noticeable in the colder weather. I would bet the bigger tires didn't create the problem, just made it more noticeable. Please post when you figure it out. I've been too lazy to tear into it so far and it doesn't seem to get any worse.
RedRunner_87
84
06-01-2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
