3rz gas guzzler
Old 08-17-2013, 09:20 AM
Pravesh's Avatar
3rz gas guzzler
Hello all,
I am from Guyana, South America, and my truck is a 99 Toyota Hilux with the 3rz engine. My ONLY problem with this truck is that is get me about 13mpg
I have checked all the electronics, valve clearances, air filter replaced, fuel filter replaced, o2 sensor changed, and the list goes on. Everything is OK.
The base timing is at 5 degrees and at idle is between 7-13 degrees.
I'm here because I am absolutely clueless as to where to look now. I have exhausted all possible avenues that I could come up with.
If you guys have any ideas I would greatly appreciate it.
The only idea I have left involves some gasoline and a match.
Kind regards,
Pravesh
Old 08-17-2013, 10:27 AM
donomite49's Avatar
what about the quality of gas? i know over here (US) gasoline brands make a difference. the amount of ethanol is a big factor in mileage,the more ethanol the worst mileage.
Old 08-17-2013, 10:28 AM
Pravesh's Avatar
I use Shell 95 octane always. I'm really not sure about the ethanol content though
Old 08-17-2013, 10:33 AM
donomite49's Avatar
i get the best mileage with shell also.
one other thing that could affect mileage and performance is the catalytic converter clogged up.
how many miles on your truck?
Old 08-17-2013, 11:04 AM
Pravesh's Avatar
the exhaust has been redone, new converter, sensor, muffler, pipe. The odometer says 85k, but I want to think for its age its actually 185k and someone turned the clock back. It is in mint condition though I must say.
pickle6415
10-19-2015 08:08 AM
larrys93pickup
09-17-2015 07:05 PM
kportercpa
Engine Swaps
09-10-2015 12:08 PM
Boomer8404
09-10-2015 09:01 AM
anndel
09-10-2015 08:50 AM
Quick Reply: 3rz gas guzzler
