2002 Tacoma no low beams
Old 08-14-2013, 05:08 AM
Vmax540's Avatar
Please help a friend.... 2002 Tacoma all at once no low beams just high beams work and the bulbs are good. Looking for suggestions or a wiring diagram. Thank you !
I see no links in the sticky's and these links to service manual do not work ? https://www.yotatech.com/forums/f128...-years-156128/
The page cannot be found
The page you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Old 08-14-2013, 05:32 AM
Fossilized
dropzone's Avatar
Was the fuse good?
Old 08-14-2013, 05:42 AM
Vmax540's Avatar
Originally Posted by dropzone
Was the fuse good?
If the fuse was blown would the high beams still work ?
Old 08-16-2013, 06:12 PM
jb451's Avatar
Had the same problem once with my camaro, turned out to be the dimmer switch... Not sure how complex that gets on newer vehicles though... Have you checked your grounds?
Old 08-18-2013, 07:18 AM
TheDurk's Avatar
I have a 4Runner. On DRL 4Runners the Hi's and Lo's have separate fuses. Yours probably does, too.
Flying91
45
04-11-2024 04:39 PM
PNWrider
10-30-2015 08:14 AM
anniesball
07-30-2015 12:14 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: 2002 Tacoma no low beams
