Staging Area For Tech Article Submissions Got a tech article to submit? Post it here
88 pickup no injector pulse while cranking. Is this correct?
Old 07-06-2013, 10:36 AM
manchmat's Avatar
the engine is cranking but will not start. i have no injector pulse while cranking. if i give a shot of starting fluid the engine will fire and at that time i will get injector pulse. is this correct? also when i turn the key on the fuel pump does not run. the fuel pump only runs while cranking the engine. is this correct? the fuel pressure seems a little low only 15 psi when cranking. if i jump the pump direct to battery i get 22 psi that still seems a little low.
manchmat is offline
steve miller
10-10-2015 01:40 AM
crashburnoveride
08-28-2015 09:20 PM
raiderhawks00
07-08-2015 06:23 PM
bryan34w
07-06-2015 05:53 PM
karbin
07-05-2015 11:37 PM
Quick Reply: 88 pickup no injector pulse while cranking. Is this correct?
