Motor Mounts
Old 06-20-2013, 04:44 PM
Swimmerboy2112's Avatar
Motor Mounts
I did some searching and can't seem to find anyone who makes poly motor/trans mounts for the 1st gen Tacos (i'm a V6). I don't really want to go with solid mounts due to the fact that they translate a lot of vibration and harshness into the cab.
If anyone has any info on where I could purchase a set of poly motor/trans mounts that would be great!
Thank you,
-Brian
Old 06-20-2013, 04:52 PM
MaK92-4RnR's Avatar
Can I ask why you're looking for better motor mounts? Do they need replacing or are you worried about the power of the supercharger being there?
Stock works just fine.
Old 06-20-2013, 04:58 PM
Good question.
The stock motor mounts are beginning to show signs of deterioration (small cracks in the rubber). Also, when all is said and done, I will be in the neighborhood of 300hp. I would like as much of that power as possible to be transferred to the wheels of the truck and not the rocking motion of the motor. That is over a 50% increase in power over the stock 5VZ-FE. Hence the desire for the poly mounts.
Old 06-20-2013, 07:55 PM
turbo8's Avatar
http://www.autopartswarehouse.com/sk...%26+Drivetrain
Old 06-21-2013, 12:25 AM
That looks like a factory replacement, i'm looking for a poly mount such as the same material that Energy Suspension uses for their stuff.
Old 06-21-2013, 03:31 PM
pattycakes77's Avatar
Don't know if these will work for you but they do list a V6, are you a 3.4 or 3.0? Email him, maybe they'll still work or maybe he can make you some.
MOUNTS
Old 06-21-2013, 05:27 PM
MOUNTS
Thank you for the link. I am a 3.4L V6. I believe those are the solid motor mounts, basically i'm looking for the poly inserts to replace the factory bushings.
Old 06-22-2013, 08:45 AM
Cameoman53's Avatar
Trailgear.com has a set of after market motor mounts, never used them or know anyone that has but something that you could look into
Old 06-22-2013, 10:08 AM
MaK92-4RnR's Avatar
i wouldn't worry about it. I ran more power than that on a 67 mustang with stock motor mounts, and it barely flexed on downshift / WOT
Old 06-23-2013, 04:54 AM
Those are the solid "bomb proof" mounts. Thanks for the suggestion though!
Don't get me wrong, this isn't something where I wouldn't run the truck if I didn't have them type of deal. Just looking for a way to put power down easier without fighting the engine rocking.
And regarding the mustang, you have to remember that chassis was built to handle more power and I am willing to bet those motor mounts were a lot stronger than the stock 5VZ-FE mounts.
Old 06-23-2013, 09:14 AM
donomite49's Avatar
have you seen these? http://www.offroadsolutions.com/prod...engine-mounts/
nice to have ORS back.
Old 06-23-2013, 11:16 AM
Those would be it!!
Just not for $449!!!!!!!!
okamikai
04-30-2018 10:19 PM
Scotto6591
09-01-2015 03:24 PM
keithporter83
07-24-2015 07:37 AM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
jon.r
07-11-2015 03:34 PM
Quick Reply: Motor Mounts
