1999 Coil swap w/ Bilstein shocks -front end looks higher
Old 05-12-2013, 06:29 AM
tonythebullet's Avatar
Hey fellow members, just wanted to start by saying that I love this forum for all the great information and the helpful members. I installed 1999 coils and Bilstein HD shocks in my 1998 4Runner yesterday and now the front appears to be sitting higher. This is not the first time I have done the '99 tall coil swap. The first time I did it was in 2009 but I kept the stock Tokico shocks. Over the past years the stock shocks didn't hold up so well (used in front and new ones in rear) so I decided to go for Bilsteins based on the reviews. I figured since I was going to have the shocks changed, I might as well get a fresh set of '99 coils that I found cheap on eBay (all 4 coils came from the same '99 Limited model). I checked the installation and everything appears to be installed correctly. The work was done by a reputable shop. I am running 31" x 10.5" tires on 15x8 rims.
This being said, I am wondering:
-Does the front need some time to settle before it's level?
-Is the rake really that bad or am I seeing things?
-If the rake is that bad, what size rear coil spacers should I get? I am leaning towards 1.5".
The truck has 377K kms on it so I don't know how much life is left in the truck otherwise I would go for OME 906. I don't tow or carry heavy loads. I mostly go offroad for mountain biking, fishing or bird hunting.
Here are some pictures for reference:
This morning (May 2013)
1999 Coil swap w/ Bilstein shocks -front end looks higher-tywso2hh.jpg
1999 Coil swap w/ Bilstein shocks -front end looks higher-ns7nycsh.jpg
March 2010 (notice the wheel gap wasn't as big as it is now)
1999 Coil swap w/ Bilstein shocks -front end looks higher-e6a6cdc.jpg
Thanke in advance for your help!!
Old 06-04-2013, 06:13 PM
Lionsden2100's Avatar
It's def higher , 1.5 " up in rear would look right.
ZGjethro
06-07-2017 11:04 PM
dirk89
10-01-2015 05:15 PM
ktm192k
10-01-2015 08:47 AM
JookUpVandetti
09-30-2015 08:58 AM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: 1999 Coil swap w/ Bilstein shocks -front end looks higher
