4wd indicator light is flashing
Old 03-25-2013, 10:52 AM
b_stone81's Avatar
Okay so I have a 2001 4runner sr5 sport and I noticed my 4wd indicator light is flashing all the time. My 4lo still works fine but I can't tell if my 4hi works at all. The button on the side of the 4wd shifter is out (where my 4hi should be off) but I don't know if it is. It seems like the ride is getting worse. I tried tapping on both actuators and still nothing. Anyone know something else?
Old 03-25-2013, 10:59 AM
250000_yota's Avatar
The light flashing indicates that the truck was unable to complete the shift from 4hi to 2hi and vice versa. You've probably got an actuator hanging up.
Old 03-25-2013, 11:09 AM
Philbert's Avatar
Double posting....
https://www.yotatech.com/forums/f2/4wd-ligh-267055/
Old 03-25-2013, 11:34 AM
b_stone81's Avatar
Well dang..... is there any way to fix that?
Old 03-25-2013, 11:41 AM
Philbert's Avatar
LOL just don't do it in the future
A moderator will likely fix at some point.
Double posts are bad because you may not get all the answers you need because the right people may see one but not the other, etc. And they are annoying and make searching in the future for folks with your same problem more difficult.
Also, a good tip for anyone, since we can only see the title of your post and not the whole body when searching "new posts", try to have as much info as possible in your title (i.e. "4WD light flahses in 2001 4Runner...what does this mean?"). This way, someone who might know the answer and sees your title is more apt to click on the post, read it, and help you (and others in the future with the same issues).
Old 03-25-2013, 12:29 PM
b_stone81's Avatar
Okay thanks for the tip
Old 03-25-2013, 01:08 PM
b_stone81's Avatar
Anyone know how to fix my 4wd problem?
Old 03-25-2013, 02:34 PM
Well I saw that you tried the tapping solution and it didn't come out, so one of the actuators is stuck good. You'll probably have to jack it up and get all four wheels off the ground to find out which one it is at this point.
Get it off the ground and start by turning the front tires. If the tire on the opposite side turns the oposite way the the front diff actuator isn't disengaging. Then check the driveshaft to the front wheels. If its still engaged in the transfer case it will be difficult if not impossible to turn by hand. While under there, you can also try tapping again because lifting it off the ground will also relieve the binding, and allow it to slip out of 4wd.
Old 03-25-2013, 02:39 PM
b_stone81's Avatar
Okay ill try that and let you know how it goes. I perciate it
Shoua
13
05-22-2016 05:19 AM
ripp96
07-25-2015 02:32 PM
ddg71
07-24-2015 01:24 PM
shisha1999
07-13-2015 11:09 PM
Quick Reply: 4wd indicator light is flashing
