Aftermarket wheels, balance problems? this will help
Old 03-16-2013, 09:15 PM
redneckj's Avatar
I am just like ALOT of people on this forum. I have done just about everything to eliminate tire shake and other possible things making the steering wheel shake. I found something that makes a real difference if you are running aftermarket wheels. Try running 12X1.5 ET lug nuts. The MB motoring wheels I have take the spline drive lugs nuts. I am going to order the 108/106 hub rings. Then the aftermarket wheels will be lug centric and hub centric just like the factory wheels. Here is a link to the lug nuts. Good luck.
http://www.ezaccessory.com/ET_Spline...FWbZQgods2QA9g
Gorilla Automotive 108-106.1 Wheel Hub Centric Rings (108mm OD x 106.1mm ID) - Pack of 4 : Amazon.com : Automotive Gorilla Automotive 108-106.1 Wheel Hub Centric Rings (108mm OD x 106.1mm ID) - Pack of 4 : Amazon.com : Automotive
gary4runner
09-24-2015 12:53 AM
skoti89
07-06-2015 07:45 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: Aftermarket wheels, balance problems? this will help
