Starter, starter releay or switch?
Old 03-14-2013, 07:10 AM
Thor95's Avatar
At random times, a twist of the key will provide a click, or sometimes a slight spin of the starter motor. Sometimes, click, click, click, (slight spin), click, start. Other times, fires right up. This morning, first crank. Then after making a stop, click, click. I took the key out, put it back and and cranked right up. Been doing this for several months. Sometimes will go a couple of weeks with no trouble. There is no pattern of it getting worse. Any thoughts?
Old 03-14-2013, 07:48 AM
93Xtra-Cab's Avatar
I can almost guarantee that your problem is starter contacts
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old 03-20-2013, 06:37 AM
jkw08's Avatar
I currently have this same problem with my 94,thought it was the clutch safety switch, so i bypassed the switch to have constant connection, didnt fix problem. I changed the starter relay thinking that might have been problem, no fix! Now im thinking it might be the starter solenoid, so im going to take the starter off this weekend and clean contacts really good before i buy another starter. Any suggestions of anything else to do would be much appreciated...
pickle6415
10-19-2015 08:08 AM
Daenerysdad
10-01-2015 07:33 PM
runnermedic
13
09-21-2015 05:20 PM
TOYOTASC
09-10-2015 05:18 PM
LJR
09-05-2015 06:02 AM
Quick Reply: Starter, starter releay or switch?
