22R Carb Swap
Old 03-02-2013, 07:36 AM
Toyota~Boy's Avatar
22R Carb Swap
Hey guys/gals. I have been experimenting with my 22r trying to increase power and possibly gain MPG. As of right now I am running a TryY header, mild cam, and everything else is factory including Carb.
I have ran webers, aisins, and hollers on my 22R engines. However I have never ran a ford motor craft. I have a really nice 2brl off a 84 ford 2.8 v6 engine. I'm wanting to swap it to my 22R.
Has anyone done this? Is anyone interested in this? If I made a adapter would anyone be interested in buying and trying one?
As of right now I'm in the process of making a adapter to bolt this to my factory intake. I will get some pictures in a few to post. In the meantime all input is appreciated.
Old 03-02-2013, 09:16 AM
Toyota~Boy's Avatar
Okay well I got started on this earlier and I'm finished with it. I do not know if it will work as I've never done this. I can build anything but making it work is different.
First step was I used the aisin mounting gasket as a template then I traced it into a peice of 1/2" steel.
Second step was to do the same only using the motor craft mounting gasket.
I then combined them together using 1/8" steel tubing.
This is what I have. Only tools I used was grinder, welder, plasma cutter, and drill. Completely finished In less then 2 hours.
I just painted it so I have not installed it to see if it works. That may come another day idk yet.
Old 03-02-2013, 01:34 PM
Toyota~Boy's Avatar
Well it works guys. It has a major throttle response now. Here's a couple vids
Old 03-02-2013, 05:52 PM
Toyota~Boy's Avatar
Old 03-03-2013, 07:36 AM
Toyota~Boy's Avatar
Well I drove it today for the first time with the ford carb and it does great. No flooding out, spitting or anything. Although I did notice something really strange. My carb and intake spacer is freezing up. It never hurt anything or caused any problems but it sure does look strange. Here's a pic
All that white is ice. It's not cold out either so I'm kinda unsure why its doing it.
Anyone got any ideas
Old 03-03-2013, 07:44 AM
Toyota~Boy's Avatar
Old 03-08-2013, 07:50 PM
Jagger_MeisterJE's Avatar
Man i wanna do this! Was there any troubles or did you make the adapter and it dropped right in and ran good? Ive got a 22re but ive been itchin to switch to carb.
Old 03-09-2013, 04:03 AM
Toyota~Boy's Avatar
I made my adapter then bolted it all up. It works great.
Old 03-25-2013, 10:25 AM
superex87's Avatar
The reason your adapter is icing up is because the stock rubber insulator prevents the adapter from getting heat from the engine. This combined with air moving through it a a very high speed is causing the humidity in the air to freeze to it lol. Its frozen condensation like a cold beer bottle on a hot day.
Old 03-25-2013, 10:27 AM
Toyota~Boy's Avatar
Oh I c said the blind man lol...
I'd take 200.00 for the carb and adapter shipped anywhere in the us
Old 04-04-2013, 11:36 AM
Rusto's Avatar
pretty nice. My stock Aisin has some dead spots in it, that adjusting the timing and messing with the air/fuel mixture just won't fix.
Old 05-17-2013, 04:01 PM
01gmc5.3's Avatar
yeah one of my friends is running this set up it is pretty responsive
Old 05-17-2013, 05:30 PM
Toyota~Boy's Avatar
Yeah it's pretty spunky. A friend of mine swapped out his EFI for this setup and loves it.
Old 05-17-2013, 08:15 PM
01gmc5.3's Avatar
you climbed any hills with the set up yett ?
Old 05-19-2013, 05:34 PM
Toyota~Boy's Avatar
Yeah it's seems fine. It hasn't sputtered or flooded out and I've had it on pretty steep banks. As I said I'm highly satisfied.
Old 05-19-2013, 07:32 PM
01gmc5.3's Avatar
have you done away with all the vacuum lines and such and cut it down to a bare minimum ? if so I might have to buy this sweet setup
Old 05-20-2013, 09:01 AM
Toyota~Boy's Avatar
Yes... I eliminated everything except vacuum advance. However I've already sold the carb and adapter
Old 05-20-2013, 02:05 PM
01gmc5.3's Avatar
well alrigth thanks any wayman and thanks for all the good info !
Old 05-20-2013, 03:11 PM
Toyota~Boy's Avatar
No problem man. Thanks for the interest
cars-guy
08-16-2020 06:59 AM
dumpster84
04-30-2016 06:03 AM
keithporter83
07-24-2015 07:37 AM
Yota.Jay
07-23-2015 08:08 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: 22R Carb Swap
