Parking Brake Adjustment
Old 02-05-2013, 07:40 PM
jmort05's Avatar
I'm trying to adjust my parking brake, and I understand how, but I'm having no luck loosening up the nuts to adjust the tension on the equalizer. I've soaked it in both WD-40 and later PB Blaster, I've even gone at it with an impact driver and nothing seems to loosen up. I'm just wondering if I am missing something? I'd consider replacing the whole adjuster assembly, but can't seem to find it at parts stores (O'Reilly and NAPA mostly)
It's a 1991 Pickup, RWD, 4cylinder, 22-RE, 1/2 ton
I've tried searching for posts on this, but ca't find anything, if anyone has better luck, I'd be happy to hear where to find it.
Thanks!
Old 02-05-2013, 08:15 PM
brianh699's Avatar
Dealer only part I'm sure you could try a junk yard but may have the same issue your wrestling with now.
Old 02-05-2013, 11:37 PM
wyoming9's Avatar
Red face
By RWD you mean two wheel drive ans not 4 wheel drive.
Time for the torch although it is right in front of the gas tank.
If one part is bad maybe time to invest in both a front and rear cable and related hardware.
Old 02-06-2013, 07:45 AM
jmort05's Avatar
Thanks for the replies, I took another look at it, and was able to make some progress, hopefully this helps someone else here:
I removed the brake lines from the equalizer, then pulled the cotter pin and pulled the adjuster arm out (took a bit of pulling, but it finally came out), then used a bench vise to hold the adjusting nut in place, and took a box wrench and a hammer to the lock nut. It took a bit, but it finally spun free.
There was white powdery residue in there, didn't look like the usual corrosion, so I'm wondering if the previous owner used some thread-lock on it?
Thanks again for the suggestions!
jashoeuh
11-26-2017 07:01 AM
terminator
07-27-2015 07:13 PM
Logz808
07-26-2015 07:09 AM
CanRunner
07-20-2015 01:29 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: Parking Brake Adjustment
