99 4 runner won't engage 4wd
Old 01-23-2013, 08:41 AM
99runaround's Avatar
Hi. I am new to this forum, and new to the 4Runner. Just bought a 99 4Runner limited. The 4wd indicator just flashes. Took it into the dealership and after 5 hrs of looking into the problem they are telling me the computer is confused. THey are saying it thinks it's in 2wd when it's 4wd and vice versa. ???
The switch on the transfer case has some apparent water damage on the inside, and there is some corrosion on some of the connections. They checked all the vacuum and electrical and everything seems to check out well. First they thought it was the front actuator, which I replaced, then they thought it was the transfer case...now they have no idea!!
Anyone have any thoughts on this one?
Appreciate it.
Old 01-23-2013, 03:47 PM
99Run's Avatar
If you have the electric version, look underneath by the trans... There are 4 solonids there that help actuate the 4WD. Check the connections on all 4 of them. They should be able to test all 4 to make sure they are working proper.
Old 01-31-2013, 06:52 AM
osoquik's Avatar
Reading time.
https://www.yotatech.com/forums/f2/4...er-ltd-131201/
zd92655
03-06-2022 12:58 PM
voiddweller
19
05-02-2016 09:10 PM
stagger_lee
03-29-2016 06:27 PM
Gamble_STi
07-01-2015 12:51 PM
TheManOutside
06-18-2015 03:32 PM
Quick Reply: 99 4 runner won't engage 4wd
