87 4runner build
87 4runner build
just starting a full build on my 87 4runner that i just picked up
.i bought it with a blown tranny and oil leaks....but the frames solid and theres not much rust at all
.already came with a 3in body lift, bilstein shocks in the front and air shocks in the back and 54in leafs for the rear that werent installed yet
.i have the rear disk conversion kit and a marlin built heavy duty tranny is on the way
.i plan to do a sas and all the suspension in the near future
.pulling the motor and tranny all tomorrow so i figured id start the thread now and see if you guys got any tips along the way
i figured drivetrain would be the first...i plan on dumping alot of money into it...i cant be the little toyota when we just put 1 tons in my buddies bronco lol
cool. if you pull your valve cover off check the condition of your timing cover and guides with that mileage unless you know theyve been replaced. check for grooves in the drivers side of the cover and the conditon of the plastic guides.
exactley why i started this...thanks man...i hope to be pulling it all apart next week..is there anything else in the motor i should look for...ive done some motor work before but nothing fuel injected or 4 cyl...im not sure if theres anything else to look out for
RedRunner_87
84
06-01-2021 01:51 PM
XtraCab
04-12-2020 05:25 AM
