rotten old yota frame
Old 11-28-2012, 05:58 PM
stovtop's Avatar
unfortunately my frame rotted out
plated several spot already in the past so ive decide to build my own from scratch ill try to get some pics up and keep you posted not very computor saavy so bear with me
Old 11-28-2012, 06:20 PM
donomite49's Avatar
now thats a project.. good luck.
pics.
Old 11-28-2012, 08:36 PM
westjohns yota's Avatar
x2 ^ cant wait to see this
Old 12-22-2012, 09:04 AM
88rnr's Avatar
Gonna keep it all stock or change over suspension etc?
Old 12-26-2012, 06:41 PM
thenewman's Avatar
duct tape man, duct tape.
Old 12-29-2012, 01:58 PM
stovtop's Avatar
i now have some pics in my profile section but i dont know how to add them here hopefully ill figure it out
cant figure out pictures dont know what a "url" is
im a redneck not a nerd
pics are in my profile section still
Old 01-06-2013, 06:53 PM
rattlewagon's Avatar
https://www.yotatech.com/~corey/help.htm
Lets see the pics!!
Old 01-11-2013, 07:28 AM
Nailit69's Avatar
Cool, that looks like some nice clean work there... I think you just came here to show off.
Upload your pics to photobucket and copy and paste the img code into your post and the pics will appear in your post.
Old 01-11-2013, 08:03 AM
redbayredneck's Avatar
Its looking good, What size (thickness and dimension) tubing you using? and Are you using dimensions off your existing frame or what?
Old 01-11-2013, 10:01 AM
Logan81Pickup's Avatar
Frame is looking good. I bet it weighs a ton though. I can easily lift up one end of my bare frame, but I'm sure you probably need a forklift or two strong guys to move yours.
Old 02-09-2013, 02:14 PM
stovtop's Avatar
this is the truck many years ago stock independent 31s 22r
Old 02-09-2013, 02:21 PM
stovtop's Avatar
after blowing up 2 22rs in six months i decided for a 350 swap which nturally called for a sas with 5 inchs of lift plus one in the body to clear distributor and valve covers
Old 02-09-2013, 02:27 PM
stovtop's Avatar
i drove it daily wheeled it quite often and towed a boat with it for camping for 5 years till she rotted out properly
heres some of the rot there is plenty more behind the gas tank and between the spring shackles since i had alredy patched up the likely spots over the years i figured i'll just build a new one from scratch
Old 02-09-2013, 02:51 PM
stovtop's Avatar
heres the back halves jigged up ready for tacking i decided to keep things simple by keeping it flat insted fo bendy and wavy like the stock frame
heres the front half tacked to the back half passenger side
drivers side frame from the front
standing the two halves together used a laser level to get them both dead nuts even
this is the rear cross member tacked in place
front crossmember tacked in everything is dead nuts level and perfectly square
heres the center main crossmember tacked in
rear tubing style crossmember with stiffeners
braced up ready for welding
all joints ground out for full penetration welds
Old 02-09-2013, 02:56 PM
ROCKLAND TOYOTA's Avatar
some of the tacoma frames we have replaced for the recall looked good enough to salvage for your project! you should comb the local toyota dealers to see if they have any.....
Old 04-02-2013, 07:25 PM
92YotaPickup's Avatar
That's a sweet frame. Looks great.
Old 04-20-2013, 04:58 AM
Kyle_GhettoFab's Avatar
holy crap thats some dedication right there and some dam good fab skills!!!
Old 04-21-2013, 09:45 AM
Gizler00's Avatar
Nice work! That's some skill you have
Old 09-18-2013, 12:31 AM
Buter's Avatar
Hi Stoytp
Sorry to dig this up from the grave but was wondering if you went off drawings for this or just carried measurements over from the old frame to the new one?
I've got a 4 door Hilux that has to go in for it's initial inspection to be registered on the island I live on and the frame is no bueno. The more I poke around, the worse it is. I either need to part it out (no market here for that) or fab up a new frame. My garage is just big enough to fab up a frame, but not big enough to strip down the old chassis to use as reference.
Great forum, first post and thanks in advance.
Buter
Old 09-18-2013, 06:42 AM
PlainJaneYota's Avatar
What do you mean "rotted", rusted?
Quick Reply: rotten old yota frame
