Getting schooled on the pinch weld
Old 09-16-2012, 10:01 PM
bryy's Avatar
1985 Toyota pickup extended cab lifted with 35's
So I had a couple questions on pinch welds for our toyotas starting with
How important are they?
If you clearence the front innner fender by hitting it with a hammer are you risking anything?
How much of the body staying together relies on that out side pinch weld that runs the inner front fender down the rockers
Also I basically cut all the pinch weld off the inner front and stich welded a bead to seal it up
I assume that will be more then fine
Do pinch welds like the inner fender one take much stress from the body flexing off road and such?
Thanks for all
Just trying to understand better
Old 09-16-2012, 10:30 PM
westjohns yota's Avatar
if im correct the pinch wled is only there too hold the two peices together and to keep moisture out, if there was too many issues nobody would tell you too beat it out
Old 09-17-2012, 04:31 AM
waskillywabbit's Avatar
It holds the body panels together.
Beat it over or cut it out and weld back together. It is important for holding the body together under flex so I wouldn't just hack it out and do nothing else
:wabbit2:
Old 09-17-2012, 09:29 AM
4Crawler's Avatar
I hammered mine flat probably 15 years ago and no problems since. Basically the pinch welds are where two pieces of sheet metal come together. Ends are bent 90* and then spot welded together to form a standing seam. Makes it easier to mfg. since you only need the spot welder on the outside of the body shell. I just bent mine over, hammered that flat with a 2-1/2 lb. hand sledge and then sprayed over the are with some primer and undercoating to protect any metal that the paint had flaked off of.
Old 09-17-2012, 11:52 AM
bryy's Avatar
Makes sense, I hammered them a long time ago and last night I bent it back and cut it off to a half inch or so( I could see the two or three layers of metal) making the pinch and using my miller 140 with .023 wire and argon co2 spot welded it up but I am a novice welder and just want to make sure that's not a high stress spot
Old 09-17-2012, 11:53 AM
bryy's Avatar
As the penetration was hard because I have experience when thicker tubes but not sheet metal
Old 09-17-2012, 11:54 AM
bryy's Avatar
Old 09-17-2012, 11:56 AM
bryy's Avatar
And the other side that's still hammered
ladybugRC
458
08-21-2020 10:41 AM
1985 4Runner
09-30-2015 10:17 AM
Toys4parts
09-26-2015 01:56 PM
runnermedic
13
09-21-2015 05:20 PM
themightykhoner
09-18-2015 02:28 AM
Quick Reply: Getting schooled on the pinch weld
