Horn Relay Location [picture]
Old 07-16-2012, 01:28 PM
adamthedroog's Avatar
Where is the horn relay?
Old 07-16-2012, 01:49 PM
DeathCougar's Avatar
Should be under the hood, not under the dash
Old 07-16-2012, 02:21 PM
Sorry I forgot to state the year. Would that be true for a 1990?
Old 07-16-2012, 02:56 PM
myyota's Avatar
If your horn isn`t working check the contact under the steering wheel.
Old 07-16-2012, 02:59 PM
I did and it's fine. I need to check the relay.
Old 07-16-2012, 03:37 PM
MudHippy's Avatar
Possibly here...
According to this...http://personal.utulsa.edu/~nathan-b.../2powersou.pdf
Or maybe it's not even shown in the pic above?
Old 07-16-2012, 04:12 PM
That's what's got me confused the green box is the starter relay but all of the FSMs that I've looked at not only says that that should be the backup relay it doesn't even say where the starter relay should be at all.
Old 07-16-2012, 04:52 PM
myyota's Avatar
Did you check the horn it self ?. I had the horn on my 86 4Runner go bad,
Old 07-16-2012, 07:02 PM
I don't know how or why but it's working now. Thanks for all of your help.
Old 07-17-2012, 10:29 AM
Stuwy123's Avatar
The contact in the steering wheel can be the culprit but also the circuit goes through the actual column.
Blast the bearings on the steering shaft (in the dash) with WD-40 to clean the crud out. My horn slowing died on me, turned out to be crud in the bearings.
Old 01-26-2022, 07:28 AM
Smokintires137's Avatar
Did you ever solve?
Attachment 192036
I'm working on the same issue with my 90 4runner. Everything I've found shows a relay attached to that white panel, about half way up. I can see that you have the same setup as mine (no relay clipped on). Did you ever get to the bottom of this? My switch is good, fuse is good, horns are good. No honk. Thanks!
Old 01-27-2022, 07:39 AM
BigBluePile's Avatar
Well, it's been 10 years so.....
....usually it's the contacts in the steering wheel.
Old 01-31-2022, 10:53 AM
RAD4Runner's Avatar
Horn Troubleshooting:
https://www.yotatech.com/forums/f116.../#post52381275
grue
11-02-2021 10:41 PM
RAD4Runner
05-18-2020 01:34 PM
Bryan4x4
02-10-2017 09:31 AM
Kiroshu
04-16-2016 03:07 PM
stevec8720
09-09-2013 07:18 AM
Quick Reply: Horn Relay Location [picture]
