Pre 84 Trucks 1st gen pickups
carb intake on 86 22re
Old 07-15-2012, 12:11 PM
john_the_great's Avatar
Can I put an old style 22r carb manifold on a 86re?
Old 07-15-2012, 04:01 PM
rustED's Avatar
You can, in 85' Toyota changed the engine blocks and heads, so I know for sure that the intake from an 85' or later 22R will work, not sure about an earlier pre-85' manifold though, I'm sure someone that knows will chime in. Do you know what year your carbed intake manifold is off of?
Old 07-15-2012, 05:18 PM
slow-mo's Avatar
You'll also need the mechanical fuel pump and the vacuum advanced type distributor. As well as all the associated vacuum metal hard lines and rubber hoses. Some vacuum lines you might be able to cap off depending on your State's emissions requirements.
Old 07-16-2012, 08:27 AM
drew303's Avatar
why would you do this? Fix the fuel injection
Doug4320
03-24-2018 10:11 PM
RatOmeter
10-22-2015 03:17 PM
tomczaksdiesel
07-26-2015 10:35 PM
Yota.Jay
07-23-2015 08:08 PM
Quick Reply: carb intake on 86 22re
