'89 22RE knocking in top front of engine
Old 02-19-2012, 05:07 PM
mattx13's Avatar
'89 Toyota Pickup 22RE 4WD, 200,000+ miles, supposedly rebuilt a little over a year ago (I've had it almost a year).
I drove it to work one night, the next day coming home it lost power, rattled like the engine was going to fall out of it, and by the time I made it home the manifold was bright orange.
Based on info on the net, videos on youtube that sounded just like mine, and advice from a mechanic buddy, I replaced the timing chain. I also found that the distributor cap was corroded, so I replaced the dist. cap and rotor button.
Cranked it back up and it's still making the same sound. It's a hollow knocking sound in the top end near the front of the motor. It almost sounds like it's under the valve cover, but I can't find anything wrong there. I only let it run for a minute and I noticed that the manifold was already getting unusually hot.
I searched and saw where some have had similar problems, but no one has mentioned the manifold getting that hot.
Anybody else had this problem? Suggestions? Help!
Thanks,
Matt
Old 02-19-2012, 06:06 PM
Bikertrash3531's Avatar
Is it overheating? I would think it would be if the manifold is getting that hot. Im a complete novice when it comes to Toyota but i would say maybe your Catalytic Converter is clogged. Good luck.
voiddweller
19
05-02-2016 09:10 PM
85run
07-08-2015 11:20 PM
puddlepirate
06-30-2015 05:08 PM
bobbybouche
06-18-2015 10:22 AM
Quick Reply: '89 22RE knocking in top front of engine
