How long did your Lower Control Arm Bushings last?
Old 11-22-2011, 01:08 PM
Run4toy's Avatar
Hello,
I'm just wondering how many people have replaced LCA bushings on their 4th Gen 4Runners, and at what mileage.
The shop says they can't align it properly because the LCA bushings are worn and weak. I want to make sure that this diagnosis is probable, and its not actually something else. I've read its a royal PITA to replace these bushings so I'd probably have the shop do it (and that won't be cheap).
I have a 130K '03 Limited V8. Its seen plenty of snowy/sandy/salty winters so I figure that might have something to do with it.
Thanks for you help!
Old 11-22-2011, 01:19 PM
scuba's Avatar
From what I've heard, the lca bushings wear out a lot more when you wheel it hard and wheel it a lot. Doesn't sound like you do either.
I'd find a different shop, honestly.
If they actually do need to be replaced, and if I remember correctly, Toyota doesn't sell just the LCA bushings. You'll have to go with brand new lca's or go with aftermarket poly urethane bushings which are known to squeak A LOT.
Old 11-22-2011, 08:48 PM
Run4toy's Avatar
I don't do much hard wheeling besides the strain of deep snow (the pushing it with the bumper kind). I'll do a couple trips in the desert every summer as well.
I think I'll take it to a different alignment shop and see if I get the same diagnosis.
Unless... is there a clever way to check the bushings without dropping the control arm?
Thanks!
FYI, for anyone reading this thread:
Toyota dealer parts department would only sell me the complete control arms for $550 a piece. However, you can buy just the bushings online for around $50 a piece (need 2 per side):
Lower control arm bushing #1 4865460030
Lower control arm bushing #2 4865560030
glowz825
01-25-2022 09:28 AM
coryc85
09-09-2015 06:24 AM
88sasturbotoy
08-11-2015 01:56 AM
1994toyota
07-17-2015 03:03 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: How long did your Lower Control Arm Bushings last?
