Best way to drain gas / fuel tank
Old 08-23-2011, 03:02 PM
foggysps's Avatar
Hi, My 2000 4Runner has been sitting in the driveway w/ a 1/2 tank of gas since crashing into a tree. I am about to finally get it back on the road, but would rather drain the old fuel out 1st. What is the best way? Should I put direct power to the pump and let it slowly drain? Do we have a drain plug just like the earlier yr 4Runners? I really would not want to drop the skid pan or tank for this.
Thanks everyone for your feedback.
Old 08-23-2011, 03:17 PM
totally a bro
vital22re's Avatar
how long has it sat?
Old 08-23-2011, 03:56 PM
foggysps's Avatar
It has been sitting in my driveway since December of 2010.
Old 08-23-2011, 04:32 PM
Sensei's Avatar
Some of the big box do it yourself stores like Lowes sell a siphon tube with a check valve. Makes siphoning gas a breeze. Usually located in the automotive section of the store. It will get most of the gas save for maybe a gallon or two.
Old 08-23-2011, 04:41 PM
93toyrunner2's Avatar
My 93 4Runner was parked for 9 months, and the fuel just did not smell right. I opened the fuel tank inspection port under the passenger side rear seat, removed the fuel pump pressure line, inserted a piece of 10 foot vacuum hose (tight fitting) on the end of it, put the other end in a 5 gallon gas can and jumped the fuel pump from the battery. It took about 6 minutes for it to finish. Then I put Stabil into the tank to treat the remainder of the gas at the bottom, filled up the tank and added SeaFoam. Changed the fuel filter, and purged the fuel rail. Started right up.
I do not know for sure that you have an inspection port on your 2000 series, maybe someone else can verify this.
Old 08-23-2011, 07:04 PM
foggysps's Avatar
I was thinking about unbolting the fuel pump assembly from inside the SUV and pump it out w/ a pump. However, would rather just jump the pump w/ power and drain into a gas can....or 3...lol
The 4Runner does start but runs very rough. I am missing the EVAP system @ the moment, due to the fact that it was crushed in the accident. I did buy another EVAP system from this forum and will install it to see if it runs better. I would just feel alot better draining the old (more than likely varnished) gas and starting fresh. I know the older 4Runners had a drain plug, making the draining process a breeze. Not sure if the 3rd Gen 4Runners have the same luxury.
Old 08-23-2011, 07:08 PM
totally a bro
vital22re's Avatar
fyi.. a year is not long enough to do any real damage. I drove a nissan sentra home from my shop that sat for 5 years with a bad motor. Replaced the motor, bump started the fuel pump and drove it home. Throw some fresh gas into it and drive it.
Old 08-23-2011, 07:17 PM
4Crawler's Avatar
Yes, should be good after 8-9 months unless there was a lot of water in it or something. But there is likely a drain plug in the tank, hidden by the skid plate. My '85 has a drain plug, towards the rear of the tank.
Old 08-23-2011, 07:23 PM
mwc0404's Avatar
my 99 4rnr recently sat for about a year while i rebuilt the front end, when it was together enough to drive i added 5 gallons of fresh gas and started it right up, plus the 10% ethanol in gas these days is supposed to somewhat act as a fuel stabilizer when its stored.
Old 08-23-2011, 07:25 PM
scuba's Avatar
My 99 Tacoma does not have a drain plug on the gas tank. I'm inclined to think the 3rd gen 4Runners don't, either.
Old 08-23-2011, 07:36 PM
totally a bro
vital22re's Avatar
They did away with the drains as people just used them to steal gas.
Old 08-23-2011, 08:23 PM
cpizzle42's Avatar
No Drain plug on your tank.
There is a acess panel under your rear driver's side seat. Don't need to use it.
Use your fuel pump to pump some of the fuel out into a container, then fill up the rest with fresh juice. Then headover to your friendly neighborhood autozone and get a fuel filter once you get rid of the not so good petrol.
Old 08-23-2011, 11:06 PM
andrewflores17's Avatar
my votes for siphoning out what you can then added to fuel stabil and some fresh gas from a gas station that sees lots of trafic so its fairly fresh but you shouldnt have to much of a problem with just adding some fuel stabil and some fresh gas
i had a silverado that sat for 9 months in my drive way had a few problems and i had my toy so didnt get around to them forever anyway had half a tank of gas i added some fuel stabil then went to my favorite shell station right off the highway and toped it off with some premium it ran like hell till the stabil gas made its way through the lines but ran fine made sure to go to a quarter tank added some fresh gas again and another bootle of fuel stabil no problems with it
u probaly could get alway with just doing that but if you can drain what you can
Old 08-24-2011, 09:16 AM
FormerVendor
ALLDATAdiy INFO's Avatar
Another vote for Stabil and top it off with some clean gas.
Old 08-24-2011, 09:21 AM
4x4jeffyota's Avatar
screw driver and a hammer seems to work very well
Old 08-25-2011, 09:56 PM
JBurt's Avatar
I had a buddy that was a mechanic in the army. When the gas tanks in the hummers would get a bullet through them they would just but a screw in them with some sealant that was bigger than the hole. Good way to make your own drain plug.
Old 08-27-2011, 08:56 AM
travolous's Avatar
Love that!
Eggslinger
06-08-2019 03:32 PM
skoti89
09-11-2015 07:46 AM
pyramid
07-30-2015 10:05 AM
TURBOrunnerNM
07-22-2015 11:01 AM
daddio
07-18-2015 10:20 AM
Quick Reply: Best way to drain gas / fuel tank
